Pages (51): Previous 16 7 8 9 1051 Next
04-11-2019, 09:55 PM
#71
Thanks but I already have plenty of engines! Could do with a soarer R154 if you have one?
04-11-2019, 09:55 PM #71
reco2k
05-11-2019, 04:42 AM
#72
toxo Thanks but I already have plenty of engines! Could do with a soarer R154 if you have one?
I have a supra r154 same box just different bell housing but the adapter plate is on ebay if you have the auto bell housing still its easy to fit, wanted to keep for my project but times arw hard and would rather sew it go into another 1uzfe project Big Grin
reco2k
05-11-2019, 04:42 AM #72
05-11-2019, 09:56 AM
#73
Not the same box Smile The soarer R154 has triple synchros, different ratios and a longer shifter position! Thanks though
05-11-2019, 09:56 AM #73
reco2k
05-11-2019, 10:48 AM
#74
toxo Not the same box Smile The soarer R154 has triple synchros, different ratios and a longer shifter position! Thanks though
I did not know that, thanks for the ibfo if i spot one around i will let you know
reco2k
05-11-2019, 10:48 AM #74
05-11-2019, 02:45 PM
#75
Actually the ratios might be the same I suppose - the part numbers for the gears are revised but they may have just made them tougher or cut the edges differently.
The problem with using a MKIII Supra gearbox these days is that any I find will be at least 20 years old! Most likely at that age to have a cracked shifter or thrust washer so would need stripping down to check and replace parts.
Edited 17-12-2011, 06:31 PM by toxo.
05-11-2019, 02:45 PM #75
reco2k
05-11-2019, 03:22 PM
#76
Well i tested this one n its very smooth, all the oils was clean when removed off a sub 100k car, looks good inside too, got some interest but can get some photos if you want
reco2k
05-11-2019, 03:22 PM #76
05-11-2019, 06:16 PM
#77
This is gonna be an immense project John.
05-11-2019, 06:16 PM #77
28-11-2019, 05:49 PM
#78
Any update on this? Big Grin
28-11-2019, 05:49 PM #78
28-11-2019, 06:30 PM
#79
Not really, it's been very cold!! Last thing I did with any of it was take the sump off the Soarer engine, I'm up there again tomorrow so I'm gonna start cleaning the parts up ready to put them on the destination engine.
28-11-2019, 06:30 PM #79
28-11-2019, 07:28 PM
#80
Awesome. I'll have to pop down some time and take a look! I've been keeping my eye out for a cheap ls400. Problem I've got is storing it though, I can't really dismantle a car at my house!
28-11-2019, 07:28 PM #80
 3 Guest(s)
 3 Guest(s)
Views 1,877
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 1,463
10-09-2024, 04:12 AM
Last Post by Jimbob-T-Lex
Views 733
21-05-2024, 04:24 AM
Replies 362
Views 31,953
06-08-2023, 02:50 PM
Last Post by john wan
Replies 1,318
Views 96,705
05-06-2023, 02:12 PM
Last Post by sarah0
Views 2,833
03-03-2023, 03:41 PM
Views 1,827
16-11-2022, 05:59 PM
Views 3,896
11-11-2022, 06:59 AM
Replies 46
Views 7,942
19-10-2022, 08:00 AM
Replies 53
Views 7,767
18-10-2022, 06:53 AM
