JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Heater control led guide
Pages (8): Previous 14 5 6 7 8
jomo
09-07-2019, 10:20 AM
#71
Well i started mine today, but found that the leds strips i had are not good enough to give a great white light for the buttons, the leds are too far apart so i get a patchy light.
Also found that getting the 3 led strip into the dial housing was a real pita!
So i'm gonna try a different method and try and use these,
[Image: 216056_10150983091316712_1359223791_n.jpg]
their not in a glass tube so should slide past the bit of plastic that works the switch.
keep you up dated....
jomo
09-07-2019, 10:20 AM #71
jomo
11-07-2019, 02:38 PM
#72
Ok guys, i did my led dials tonight (what a pain in the fecking ass!)
Anyways i'm not that happy with how it turned out as its not a white as i was hoping!
Plus the god **** clock has stopped working!!!
Moley did you sort yours out?
Fortunately it was a spare that i picked up so still got my orig one to try again, if i ever muster the patience to do it again!
Pic's
[Image: 202660_10150987608416712_31427512_o.jpg]
[Image: 620550_10150987633516712_2089633229_o.jpg]
[Image: 327832_10150987607991712_1518345078_o.jpg]
jomo
11-07-2019, 02:38 PM #72
Pic's
jomo
12-07-2019, 09:28 AM
#73
Well today i found that the heater now only blows hot (started off cold till i moved the dial) and the air flow direction dial does nothing, the heated rear window works!
This is heading for the BIN!!!
jomo
12-07-2019, 09:28 AM #73
12-07-2019, 09:29 AM
#74
Has the little brass pin at the back of the control knob fallen out when you took it apart?
Also if it's a different model to your one it may only blow one temp.
12-07-2019, 09:29 AM #74
jomo
12-07-2019, 02:15 PM
#75
The small brass pins did keep falling out till i hot glued them in, not too sure if its the same model or not, i know that it came out of a 99 year and mines a 2000.
jomo
12-07-2019, 02:15 PM #75
JayJay1374
21-02-2020, 05:21 AM
#76
has anyone got anymore pictures of doing this? (where to wire the leds to?) or circuit diagrams? thanks
http://www.facebook.com/Sxe10CrewUk
Stickers available!!!, PM me.
JayJay1374
21-02-2020, 05:21 AM #76
reco2k
21-02-2020, 05:58 AM
#77
JayJay1374 has anyone got anymore pictures of doing this? (where to wire the leds to?) or circuit diagrams? thanks
I wired then into the switched feed on the harness that plugs into the unit. Just routed all the wires out of the redundant bulb holes. Om if u need anymore info mate
Ross
reco2k
21-02-2020, 05:58 AM #77
Ross
Views 568
12-03-2021, 11:09 AM
Views 672
25-07-2019, 11:59 AM
Last Post by lex2oos
Views 634
18-05-2018, 01:25 PM
