JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Help still Big Problems with my lexus is200
Pages (13): Previous 17 8 9 10 1113 Next
lexynik
Unregistered
05-02-2017, 11:09 AM
#81
10/10 for perseverence mate - i guess if your throttle assy has not been fitted properly and "SET UP" correctly you could get that kind of problem,you dont have much luck with garages do you,i cant see why that would make it cut out though but maybe it messes everything up ie air/fuel mixture etc--mind you i know nothing so ,,,,,
have you still got that guy coming tomorrow ?
lexynik
05-02-2017, 11:09 AM #81
05-02-2017, 11:46 AM
#82
It does sound like a problem with the throttle cable, probably connected with the fact that you had the throttle body replaced (e.g. the cable wasn't reattached properly or some other problem related to the cable).
Where do things stand relating to the speed sensor ?
05-02-2017, 11:46 AM #82
jayson2323
05-02-2017, 12:29 PM
#83
Thanks Nick, I am glad to have the car with me that way I can try all these things, the guy is still coming tomorrow but unfortunately he does not have any is200 parts but he will give me the codes from the lexus diagnostics scanner which will help
Steve what is weird though is you have to let it cool down and it will start again so do you think this could still be related to the throttle body
The speed sensor I get sometime next week
Also I forgot to mention when it cuts out got the mrs to keep on trying to start it and stood outside and you can actually hear the car stutter and there is like a poppin noise from the exhaust as if the car is struggling to breathe, are these symptoms of anything obvious?
Thanks guys for the advice, it is always really appreciated
jayson2323
05-02-2017, 12:29 PM #83
phil
05-02-2017, 08:05 PM
#84
I had a problem like that a few years back and it was down to the coil, but that was quite an old car, not sure if that helps or you have already checked the coil
phil
05-02-2017, 08:05 PM #84
lexynik
Unregistered
05-02-2017, 11:17 PM
#85
good luck today jayson - i hope he gets to the bottom of it
lexynik
05-02-2017, 11:17 PM #85
jayson2323
05-02-2017, 11:54 PM
#86
Gord there are 2 cats on the is200, what would be the best way to see if they have brokendown?
Phil coil number 5 is malfunctioning, you think its struggling when it gets hot?
I was told by the garages the coil is not misfiring but it keeps coming up with the code
Thanks guys, advice is appreciated
jayson2323
05-02-2017, 11:54 PM #86
06-02-2017, 12:00 AM
#87
There's 3 cats on the is200 matey, 2 pre cats in the manifold down pipe and the main cat under the car, you'd have to take the down pipe off to see if its the pre cats, it sometimes happens in the supercharged is200's so people have the pre cats removed?
06-02-2017, 12:00 AM #87
jayson2323
06-02-2017, 01:00 AM
#88
if i had to remove the 2 precats what would I replace them with?
does the is200 always show the diagnostic code if a cat is not working?
jayson2323
06-02-2017, 01:00 AM #88
06-02-2017, 01:43 AM
#89
You don't need to replace the pre-cats, it will run fine without them. Or if you still wanted them you could find a manifold (with pre-cats built in) from a breaker's.
Don't know for sure about the second question. I would have thought it should do, given that there are sensors after both the pre-cats and the main cat.
06-02-2017, 01:43 AM #89
jayson2323
06-02-2017, 01:52 AM
#90
that is fine then, only question is if i remove the precats won't i need to find pipe to ake up for where they hve been taken off?
will the engine light come on without the precats on the car?
jayson2323
06-02-2017, 01:52 AM #90
Views 413
13-12-2023, 02:06 PM
Views 545
09-11-2023, 03:46 AM
Last Post by Dinho
Views 916
06-11-2022, 01:49 AM
Views 3,043
02-11-2022, 10:55 AM
Views 370
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,595
23-02-2022, 01:20 PM
Views 412
18-10-2021, 02:04 AM
Views 360
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 576
03-09-2021, 11:04 AM
Views 534
29-08-2021, 09:59 AM
