JapCarForum Cars, Cars, Cars! Project Cars It's a Supra Thing.....
Pages (25): Previous 17 8 9 10 1125 Next
14-06-2018, 04:10 AM
#81
*mini update*
Just got back from Toyota after spending the best part of £300 on parts, my gearbox and engine oil has also arrived thanks to Opie and my replacement ARB's are also on their way.
So the list of immediate things to replace are:
- HT leads
- spark plugs
- dizzy cap
- rotor arm
- fuel filter
- V Belt
- drop links (need to order these)
- ARB's when they arrive
- Track rod ends
- buy and fit parts for custom induction kit
- Oil filter
- drain and put new engine and gearbox oils in
Once all this is done she's going back to JPS to have new cambelt, rear main seal replaced as i've got a small oil leak from the gearbox, new transmission mount (i'll be ordering a TRD one and giving this to JPS to put on at the same time as the rear main seal), i'm debating whether to get them to take the head off the engine to find out why i've got low compression on cylinders 3+4
14-06-2018, 04:10 AM #81
*mini update*
- HT leads
- spark plugs
- dizzy cap
- rotor arm
- fuel filter
- V Belt
- Track rod ends
- Oil filter
Fozzy
14-06-2018, 05:08 AM
#82
Ill bet you will be a lucky git and find its just the head gasket going between the two cylinders. I find it unlikely that it would be burnt valves or dead rings, especially as its 2 cylinders side by side
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
14-06-2018, 05:08 AM #82
14-06-2018, 05:12 AM
#83
Hurricane Ill bet you will be a lucky git and find its just the head gasket going between the two cylinders. I find it unlikely that it would be burnt valves or dead rings, especially as its 2 cylinders side by side
It's possible but my money's on the valves due to evidence of previous cack servicing, which is why I don't think it's worth doing. The compression's not low enough to be an issue (it just takes a few more turns to start) and the engine is ultimately going in the bin.
My 2p, which Dan is already very much aware of Smile
14-06-2018, 05:12 AM #83
fluff
14-06-2018, 06:07 AM
#84
Just jiggle the bendy thing and all will be well.
fluff
14-06-2018, 06:07 AM #84
Fozzy
14-06-2018, 06:24 AM
#85
What was comp. on 3/4 about 150/160 wasnt it? When it was comp. tested did they do it twice, once with dry bores and then again with a couple of drops of oil down there?
Fozzy
14-06-2018, 06:24 AM #85
23-06-2018, 04:44 AM
#86
with the impending work about to be done I set about a new induction kit for the Supra, the issue is that there isn't many NA induction kits available on the market and the ones that are about are very expensive and only make up half the intake piping.
So I decided to make my own but first the design process, mocked something up today of how it will look
[Image: inductionkit.jpg]
it should be fairly straight forward, for the MAF sensor I will drill a hole in the intake pipe and put a rubber grommet on it so that the sensor can be easily removed, the fiddly bit is going to be the breather take off as i'll need to drill a hole into the 45 degree elbow and then silicone in the alloy joiner and connect the breather pipe onto this.....funny how simple everything seems in your head
Edited 04-08-2011, 02:22 PM by Dan_Turism0.
23-06-2018, 04:44 AM #86
23-06-2018, 05:02 AM
#87
On behalf of my dad:
Dan you can buy our piping to fit a 2JZ, you'll just need your own filter!
23-06-2018, 05:02 AM #87
23-06-2018, 05:14 AM
#88
Does your piping go from the throttlebody mate? Any pics?
23-06-2018, 05:14 AM #88
23-06-2018, 06:08 AM
#89
It just joins the other side of that silicone hose where the jubilee clip is by the engine cover:
[Image: 2011-01-27155045.jpg]
23-06-2018, 06:08 AM #89
23-06-2018, 06:10 AM
#90
[Image: 2011-01-27155059.jpg]
There you can see the oil breather pipe.
23-06-2018, 06:10 AM #90
Replies 257
Views 22,341
03-01-2024, 08:24 AM
Views 907
31-10-2023, 10:05 PM
Replies 79
Views 4,282
03-09-2023, 10:30 AM
Replies 29
Views 3,281
29-08-2022, 01:37 AM
Last Post by Berg
Views 2,182
06-05-2021, 10:24 PM
Last Post by Connor376
Replies 53
Views 4,285
02-03-2021, 10:06 PM
Last Post by TheAmerican
Replies 39
Views 2,892
20-01-2021, 04:47 AM
Replies 132
Views 5,390
11-11-2020, 01:34 PM
Last Post by japgirl
Views 825
27-09-2020, 03:43 PM
Last Post by purplewitch
Replies 106
Views 5,355
05-09-2019, 12:12 PM
Last Post by racestyle
