JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Idle Tick Over
Idle Tick Over
Idle Tick Over
Pages (3): 1 2 3 Next
Cous3
08-07-2016, 09:05 AM
Can anyone tell me is there a way that the idle tick over can be increased on the IS200 and if so how/where can this be done?
Mine hoovers around the 600 mark since I fitted the induction ages ago, but lately it's become a pain and I need to increase it a tad.
Keith
(remembers the old days of his Capri/Cortina/Mini when a simple screw on the carb was all that needed to be tweaked.....:confused1Smile
Cous3
08-07-2016, 09:05 AM #1
Keith
08-07-2016, 09:25 AM
I don't think you can just alter it like you could in the all days, think it's all under electronic control.
So you think it's idling too low now ? Does it make a difference if the A/C is on or not (since the A/C compressor affects the idling speed) ?
Have you tried resetting the ECU to make it re-learn things and to see if that helps ?
08-07-2016, 09:25 AM #2
08-07-2016, 09:27 AM
Is it causing any problems?
08-07-2016, 09:27 AM #3
08-07-2016, 09:32 AM
steviewevie I don't think you can just alter it like you could in the all days, think it's all under electronic control.
The ECU should correct the idle when the A/C is turned on, it should idle as normal.
As Steviewevie says re-set the ecu and go from there.
08-07-2016, 09:32 AM #4
RT
08-07-2016, 09:39 AM
Is the IS completely FBW throttle?
RT
08-07-2016, 09:39 AM #5
The idle should be corrected but there could (in theory) be a problem with the a/c compressor and/or circuitry that is causing a problem.
08-07-2016, 09:39 AM #6
08-07-2016, 09:42 AM
Roadside Tech Is the IS completely FBW throttle?
No its a wired throttle, but assisted by a throttle motor
steviewevie The idle should be corrected but there could (in theory) be a problem with the a/c compressor and/or circuitry that is causing a problem.
why the AC? Cous3 hasnt said what problem its causing yet?
08-07-2016, 09:42 AM #7
08-07-2016, 09:43 AM
Sparkystav No its a wired throttle, but assisted by a throttle motor
Just answering 2tongues point about the a/c. The a/c is just one of several possible causes, not saying that's definitely it at all.
08-07-2016, 09:43 AM #8
RT
08-07-2016, 09:48 AM
You mean cable assisted by a motor?
Are there no adjustments on the throttle stop for idle adjustment (although they shouldn't be used on a modern motor ideally)
RT
08-07-2016, 09:48 AM #9
08-07-2016, 09:59 AM
The accelerator pedal operates a cable which is connected to the throttle body. A sensor there measures the opening on the cable, which feed a signal to the ECU. The ECU then tells the throttle body control motor how much to open the throttle.
In the event of a malfunction the electrical control drops out, and the mechanical throttle cable directly operates the throttle itself.
08-07-2016, 09:59 AM #10
Views 173
12-05-2020, 03:26 AM
Last Post by Ji123
Views 603
13-12-2019, 06:02 AM
Last Post by Phil01
Views 630
15-04-2019, 02:14 AM
Views 502
16-11-2018, 10:17 AM
