JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Whining noise when idle
James S
12-12-2019, 01:43 PM
When my car has been de-frosting and warming up over the last couple of days, it has been making an awful noise.
It stops as soon as you put the clutch down. Is it the clutch release bearing? The noise has been around happening for a while, but has got a lot worse recently.
My clutch is healthy, does it need the gearbox out to fix it? And what happens if the bearing fails? My is200 is a daily and I need it to be reliable for work and can't be without it.
James S
12-12-2019, 01:43 PM #1
12-12-2019, 02:21 PM
If it's just on idle could it be a loose belt or something? Not sure why it would disappear when you put the clutch down though. Hopefully someone more knowledgeable has an answer!
12-12-2019, 02:21 PM #2
Does sound like the bearing, if it fails and falls apart itll fall about the bell housing, as soon as you put your clutch down it'll rip apart the pressure plate.
Yes the gearbox needs to come out unfortunately.
12-12-2019, 02:21 PM #3
12-12-2019, 02:22 PM
I'm assuming its when idling as well
12-12-2019, 02:22 PM #4
13-12-2019, 12:26 AM
Whining noise when idle ... That's a LexusPat Smile
13-12-2019, 12:26 AM #5
James S
13-12-2019, 03:52 AM
Lol! Yeah, it's been when idling. Really not sure whether to spend the money on it as i spent a fortune replacing all the cooling system and brakes last year. It needs a trip to the body shop and now this. Grr!
James S
13-12-2019, 03:52 AM #6
13-12-2019, 04:22 AM
I would say stav is right, mine made the same noises, only needed the bearing so wasn't a big cost.
13-12-2019, 04:22 AM #7
13-12-2019, 04:44 AM
Oi how do I get mentioned oh wait that's Sam not doing anywork as per yet she's so busy :lol:
13-12-2019, 04:44 AM #8
13-12-2019, 05:01 AM
Lexuspat Oi how do I get mentioned oh wait that's Sam not doing anywork as per yet she's so busy :lol:
where is the "like" buttonBig Grin
13-12-2019, 05:01 AM #9
13-12-2019, 05:18 AM
I was waiting for a software update so made a coffee and took an interest in poor James's troubles :p ...
13-12-2019, 05:18 AM #10
Views 240
15-01-2022, 02:19 AM
Views 235
24-07-2021, 05:07 AM
Last Post by phaebo
Views 137
12-05-2020, 03:26 AM
Last Post by Ji123
Views 510
15-04-2019, 02:14 AM
Views 410
16-11-2018, 10:17 AM
Replies 24
Views 1,084
04-08-2016, 04:10 PM
Last Post by Phil01
