JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Engine Revs hunting on Idle
S
16-11-2018, 09:36 AM
Evening all,
the car has done this since i bought it, ive cleaned the TB and reset the ECU and it continued to hunt on idle.
it sits at around 900rpm for a while and then the revs drop a little bit and the lights dim (if on) and the revs almost immediatley pick up and then it idles at 1000rpm for a while before returning to 900.
A video is below (Ignore the warning light its because i used the wiring from the parcel shelf light for the boot spoiler and i havnt bothered to sort it)
my question is: Is this normal idle behavior for a warm 1G-FE or is there a problem?
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid77.photobucket.com%2Falbums%2Fj60%2Fdopple-ganger%2FVIDEO0025.mp4">
S
16-11-2018, 09:36 AM #1
Evening all,
S
16-11-2018, 09:37 AM
hopefully this link will work
[Image: th_VIDEO0025.jpg]
S
16-11-2018, 09:37 AM #2
16-11-2018, 09:56 AM
have you got the aircon on?
i would bet its the clutch dropping in and out, its supposed to do that
16-11-2018, 09:56 AM #3
S
16-11-2018, 10:06 AM
yeah the aircon is almost always on lol
EXCELLENT i was worrying you were going to say its an expensive problem!
S
16-11-2018, 10:06 AM #4
S
Thanks alot btw stav Big Grin
S
16-11-2018, 10:06 AM #5
16-11-2018, 10:17 AM
just try it mate, turn the aircon off and it shouldnt happen then.
the ecu does attempt to compensate but it cant be perfect
16-11-2018, 10:17 AM #6
Views 244
15-04-2022, 03:17 AM
Views 300
15-01-2022, 02:19 AM
Views 663
17-08-2021, 03:49 AM
Last Post by mattlaw
Views 172
12-05-2020, 03:26 AM
Last Post by Ji123
Views 324
22-04-2020, 10:02 PM
Last Post by S
Views 473
01-04-2020, 02:53 AM
Views 238
09-03-2020, 11:31 PM
Views 602
13-12-2019, 06:02 AM
Last Post by Phil01
Views 488
15-11-2019, 03:48 PM
Views 456
26-06-2019, 10:25 AM
