JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Limping engine, help!
CammyGrieve
19-03-2020, 10:59 PM
Few problems now with the engine, there is oil all over the engine, i have bought a new rocker cover gasket to see if that cures the problem, and some spark plugs as it is misfiring.
It has now started to flash the traction control and engine management light on and off on the dash board and struggles to pull ... anyone any ideas what this could be?
Also have an oil catch tank, but the breather pipe is breathing very heavily, looks like the engine is smoking when it isnt ... any ideas??
Is my car going to die Sad
CammyGrieve
19-03-2020, 10:59 PM #1
19-03-2020, 11:47 PM
Sounds like you need to see a mechanic... urgently !
19-03-2020, 11:47 PM #2
20-03-2020, 12:29 AM
Flashing ecu light says coil packs to me.
20-03-2020, 12:29 AM #3
S
21-03-2020, 07:35 AM
You need to get an engine code reader mate!
S
21-03-2020, 07:35 AM #4
31-03-2020, 10:23 AM
have you got anywhere with it mate
31-03-2020, 10:23 AM #5
CammyGrieve
31-03-2020, 11:52 PM
Yeah, replaced all the spark plugs and the coil packs (dear job) then it ran smooth as you can dream of, then 3 of the coils have blown again.
There is oil getting into the back 3 cylinders some how ... so the car is parked up just now, either stem oil seals or piston rings ....
CammyGrieve
31-03-2020, 11:52 PM #6
CammyGrieve
31-03-2020, 11:59 PM
Ah,
Update this morning, had it all stripped, doenst look too bad ... however there are no seals on the coils, this might be why it is limping, put on a new rocker gasket and she seems to be running okay with no more trace of oil in the cylinders ....
Fingers crossed it stays that way!
CammyGrieve
31-03-2020, 11:59 PM #7
Ah,
01-04-2020, 02:25 AM
Glad you sorted it mate! Hope it works out.
01-04-2020, 02:25 AM #8
01-04-2020, 02:53 AM
Fingers crossed mate
01-04-2020, 02:53 AM #9
Views 195
15-04-2022, 03:17 AM
Views 240
15-01-2022, 02:19 AM
Views 557
17-08-2021, 03:49 AM
Last Post by mattlaw
Views 252
22-04-2020, 10:02 PM
Last Post by S
Views 197
09-03-2020, 11:31 PM
Views 350
15-11-2019, 03:48 PM
Views 379
26-06-2019, 10:25 AM
Replies 18
Views 872
20-02-2019, 07:14 AM
Views 1,008
18-11-2018, 04:15 AM
Views 410
16-11-2018, 10:17 AM
