JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission engine warning light
13-02-2020, 04:07 AM
Right guys, my engine warning light has come on, not sure why. I've also noticed that the exhaust smells a bit "odd" over the last 2 weeks or so.
What are my options?
13-02-2020, 04:07 AM #1
13-02-2020, 04:17 AM
You need the code read. Could be anything till then.
13-02-2020, 04:17 AM #2
13-02-2020, 04:33 AM
thought as much, thanks Stav!
Anyone near me got one?
13-02-2020, 04:33 AM #3
dalegt4
13-02-2020, 04:48 AM
can you not do what you can do on the gtfour and bridge the terminals and read the flashes off the dashboard ecu lights, thats how we do it without a reader
dalegt4
13-02-2020, 04:48 AM #4
13-02-2020, 05:41 AM
quite likely an o2 sensor but until the codes are read were all guessing mate
13-02-2020, 05:41 AM #5
13-02-2020, 05:44 AM
dalegt4 can you not do what you can do on the gtfour and bridge the terminals and read the flashes off the dashboard ecu lights, thats how we do it without a reader
No, IS200 is fully OBD2.
I've got a reader Koss, we can look at it when we do your other rear suspension arm.
13-02-2020, 05:44 AM #6
13-02-2020, 06:08 AM
Awesome, thanks Big Grin
13-02-2020, 06:08 AM #7
dalegt4
13-02-2020, 06:24 AM
ooo mind you abit more new than the Four!
shame though, its nice to be able to find the faluts without having to buy expensive gear, when we read my car with the reader it always tells us off about having higher than stock boost levels reached. Big Grin
and i do rather like the abillity to see the max rpm limit reached and all other bits. nice
dalegt4
13-02-2020, 06:24 AM #8
20-02-2020, 09:01 AM
Right, it was a VVTi problem, the light has now come back.
What should I be doing? I reckon the engine is overdue on a new timing belt.
20-02-2020, 09:01 AM #9
20-02-2020, 09:07 AM
Well the code in question was vvti sensor wasn't it? So it won't be timing belt related...
Edit: I take that back!! :lol:
http://caphector.com/atoyota/techinfo.to...ip1346.pdf
"Mechanical system malfunction (Skipping teeth of timing belt,
belt stretched)"
Edited 02-04-2012, 12:58 PM by toxo.
20-02-2020, 09:07 AM #10
belt stretched)"
Views 423
15-04-2023, 09:06 AM
Views 572
15-01-2023, 08:08 AM
Views 1,119
17-08-2022, 09:38 AM
Last Post by mattlaw
Views 664
23-04-2021, 03:50 AM
Last Post by S
Views 973
01-04-2021, 08:42 AM
Views 449
10-03-2021, 05:19 AM
Views 1,189
14-11-2020, 09:36 PM
Views 885
25-06-2020, 04:13 PM
Views 983
06-12-2019, 07:02 PM
Last Post by Rolex
Views 2,087
18-11-2019, 10:04 AM
