JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Engine rebuild
Engine rebuild
Engine rebuild
LEX11S
13-06-2018, 06:19 AM
Afternoon all
i need some help on my engine i have got some 1ggte rods and pistons
to put in my engine
things i need help on i need some piston rings are they them same as 1gfe ones?
also looking for some new rod cap bolts(big end bolts) are they the same as 1gfe? is there any stronger ones?
and last thing ive been reading somewhere the crank is the same as a 1fe is this true?
Thanks
LEX11S
13-06-2018, 06:19 AM #1
Afternoon all
to put in my engine
Thanks
13-06-2018, 06:48 AM
i thought the crank was different or so i was told...
13-06-2018, 06:48 AM #2
LEX11S
13-06-2018, 07:28 AM
Just found out from lexus they are the same part number the piston rings are differnt
and the cap bolts are the same as a 1gfe
LEX11S
13-06-2018, 07:28 AM #3
RichyUK
14-06-2018, 12:33 AM
i checked with toyota recently and i'm sure the rings were discontinued. As were the 1ggte pistons. Maybe it'll have to be aftermarket ones.
Lucky to get the rods and pistons, were did you get them? im after some to rebuild my old engine.
RichyUK
14-06-2018, 12:33 AM #4
14-06-2018, 02:15 AM
he got the rods and pistons from me mate as i was going down that route originally then got the fully forged and bored block instead and then now i dont have a lexus lol
so i have the whole lot up for sale lol
14-06-2018, 02:15 AM #5
Fozzy
14-06-2018, 02:29 AM
Ok i think Ormi will be best to confirm this for you, and it may be worth dropping him a PM.
I believe the piston rings will be the same as the 1G-FE ones, as they are the same bore and same qty of rings i.e 2 compression rings and 1 oil scraper.
As for the big end bolts, check out ARP, they will definately have some available
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
14-06-2018, 02:29 AM #6
14-06-2018, 02:46 AM
as far as im aware there are ARP bolts avaliable for inside the engine (remember im electronics not mechanical )
here si the extract from my add which lists ARP 2000 what ever that means lol
et of steel "H" section con rods. with forged pistons to suit the Toyota Lexus 1GFE IS200 engines. The rods come with bronze bushed small ends with 18mm pin size and are longer than std to enhance rod angle and torque output. Oil holes for piston cooling are incorporated as per std. ARP 2000 bolts are included as std. Pistons are forged aluminum with revised ring pack, piston pin offset and compression height to reduce piston noise and increase power from std factory design. Compression ratio is as per std. Pins are floating with wire clips rather than the std interference factory fit. Crown design differs from std to increase swirl for increased combustion efficiency.
The block has been Bored out from 75mm as standard to the 76mm it was stripped back and the oiled up the outside casing has been painted in black.
all new Toyota Bearings have been used throughout.
14-06-2018, 02:46 AM #7
Fozzy
14-06-2018, 02:59 AM
Well the ones used on your H-section rods will probably be different to std 1g-fe ones, although they may be the same
Fozzy
14-06-2018, 02:59 AM #8
RichyUK
14-06-2018, 04:28 AM
nearly all aftermarket forged conrods come with arp's fitted as standard Smile
RichyUK
14-06-2018, 04:28 AM #9
LEX11S
14-06-2018, 04:51 AM
The pistons on the 1ggte are not the same as 1gfe differnt part number the rings you can still get from toyota they are 145 pounds for the set 2 weeks del
the bolts that are on the ones that rabster have are not the same they just use a bolt the std 1gfe/1ggte are bolts and nuts going to have alook around on arp site see if there is something the same?
Big end shells are not the same as 1gfe but you can still get them from toyota in all the sizes
LEX11S
14-06-2018, 04:51 AM #10
Views 244
15-04-2022, 03:17 AM
Views 300
15-01-2022, 02:19 AM
Views 663
17-08-2021, 03:49 AM
Last Post by mattlaw
Views 324
22-04-2020, 10:02 PM
Last Post by S
Views 473
01-04-2020, 02:53 AM
Views 238
09-03-2020, 11:31 PM
Views 488
15-11-2019, 03:48 PM
Views 456
26-06-2019, 10:25 AM
Replies 18
Views 1,078
20-02-2019, 07:14 AM
Views 502
16-11-2018, 10:17 AM
