JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Is200 help please
Is200 help please
Is200 help please
Gr1NcH
19-02-2019, 10:20 AM
Hi guys
I'm probably going over a prev post so sry if you find that your repeating yourself.
Problem: at around 50mph I seem to feel a very slight wobble/vibration. The steering wheel seems ok and I've recently had the front wheels rebalanced. I have a 40mm low profile tyre fitted. I've looked, pulled and pushed all the suspension parts and all seems ok. I recently read on here that the drive shaft may be a cause of a similar symptom. We're would I need to look to see if there is a prob in this area. I also noticed the the two rear bars on the axle that connect to the rear wheels have a very slight play from left to right(about 2mm) is this normal.
Any help would be great. Thank you.
Regards. Geoff
Gr1NcH
19-02-2019, 10:20 AM #1
Hi guys
Regards. Geoff
posty
19-02-2019, 10:27 AM
It could be your front brake discs have warped. Its happened to me before.
posty
19-02-2019, 10:27 AM #2
19-02-2019, 10:30 AM
surely you'd have symptoms before 50mph though?
19-02-2019, 10:30 AM #3
posty
19-02-2019, 10:34 AM
When mine were warped it came in between 50 and 70mph. Nothing at any other speed. Fitted new discs and it went away!
posty
19-02-2019, 10:34 AM #4
Gr1NcH
19-02-2019, 12:20 PM
Uum. This may explain the pair of brand new discs and pads that were in the boot when I bought the car Smile
I guess that's my first port of call.
Gr1NcH
19-02-2019, 12:20 PM #5
19-02-2019, 12:28 PM
First thing to do would be the cheapest thing - get the rear wheels balanced as well.
19-02-2019, 12:28 PM #6
19-02-2019, 08:46 PM
How old is the car,
I had similar sympton when my brake calliper siezed up
19-02-2019, 08:46 PM #7
How old is the car,
clossie
19-02-2019, 11:23 PM
was brake disc for me also. although I sic have to
push the pedal before the wobble which Gr1nch hasn't stated he is doing or not. was thinking perhaps a ball joint issue
clossie
19-02-2019, 11:23 PM #8
P.Lindblom
20-02-2019, 12:20 AM
If it's your front discs or wheels that are causing the problem you should feel the wobble through your steering wheel. if you feel a wobble but the steering wheel is still I'd check the rear wheels and discs.
P.Lindblom
20-02-2019, 12:20 AM #9
Gr1NcH
20-02-2019, 12:50 AM
Thanks guys
Gr1NcH
20-02-2019, 12:50 AM #10
Thanks guys
Views 345
13-12-2023, 02:06 PM
Views 485
09-11-2023, 03:46 AM
Last Post by Dinho
Views 759
06-11-2022, 01:49 AM
Views 1,442
02-11-2022, 10:55 AM
Views 316
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,268
23-02-2022, 01:20 PM
Views 362
18-10-2021, 02:04 AM
Views 480
03-09-2021, 11:04 AM
Views 497
29-08-2021, 09:59 AM
Replies 35
Views 7,830
04-08-2021, 04:34 AM
Last Post by cjoseph
