JapCarForum Club Sponsor Invisible Touch Detailing The Do Luck Supra
The Do Luck Supra
The Do Luck Supra
Pages (3): 1 2 3 Next
07-04-2019, 07:54 AM
Here we have Jamesy's writeup for his newely acquired Do Luck Supra!
The car was booked in for a Stage 1 paint enhancement, so not all defects will be removed in this process. As a general rule original Supra paint is quite soft, as this car has been fully painted it was a little unknown what the paint hardness would be like. I can tell you now, that its much harder Smile
So, taking a walk around the car lets see what weve got...
[Image: DSC07389.jpg]
[Image: DSC07390.jpg]
[Image: DSC07391.jpg]
[Image: DSC07392.jpg]
[Image: DSC07393.jpg]
[Image: DSC07394.jpg]
[Image: DSC07395.jpg]
[Image: DSC07396.jpg]
[Image: DSC07397.jpg]
[Image: DSC07398.jpg]
[Image: DSC07399.jpg]
[Image: DSC07400.jpg]
[Image: DSC07401.jpg]
[Image: DSC07402.jpg]
[Image: DSC07403.jpg]
[Image: DSC07404.jpg]
[Image: DSC07406.jpg]
[Image: DSC07407.jpg]
[Image: DSC07408.jpg]
07-04-2019, 07:54 AM #1
07-04-2019, 07:55 AM
[Image: DSC07409.jpg]
[Image: DSC07410.jpg]
[Image: DSC07411.jpg]
[Image: DSC07412.jpg]
[Image: DSC07413.jpg]
[Image: DSC07414.jpg]
Starting off, the tyres were cleaned with All Purpose Cleaner
[Image: DSC07415.jpg]
Wheels with Bilberry, which is safe for all types of alloys, including chrome
[Image: DSC07416.jpg]
Calipers also cleaned with APC
[Image: DSC07417.jpg]
[Image: DSC07418.jpg]
All door, boot, fuel shuts, window trim, lights and scuttle panel cleaned with APC
[Image: DSC07419.jpg]
[Image: DSC07420.jpg]
[Image: DSC07421.jpg]
[Image: DSC07422.jpg]
[Image: DSC07423.jpg]
[Image: DSC07424.jpg]
[Image: DSC07425.jpg]
[Image: DSC07426.jpg]
The car was then jetwashed, snowfoamed, rinsed off after 5 mins and washed using Shampoo Plus, leaving this
[Image: DSC07427.jpg]
07-04-2019, 07:55 AM #2
Being a mild day outside, the car was clayed using Last Touch as lube to remove bonded contamination washing would not remove
[Image: DSC07428.jpg]
The rear number plate was cleaned with Tar & Glue to remove the residue from a previous plate applied over the top
[Image: DSC07429.jpg]
[Image: DSC07431.jpg]
After being washed again the car was taken inside to be dried and inspected, lots of swirls and faded paint was now very apparent
[Image: DSC07448.jpg]
[Image: DSC07453.jpg]
[Image: DSC07455.jpg]
[Image: DSC07457.jpg]
[Image: DSC07459.jpg]
[Image: DSC07465.jpg]
[Image: DSC07466.jpg]
[Image: DSC07468.jpg]
[Image: DSC07469.jpg]
[Image: DSC07470.jpg]
[Image: DSC07473.jpg]
[Image: DSC07476.jpg]
[Image: DSC07477.jpg]
[Image: DSC07482.jpg]
[Image: DSC07485.jpg]
[Image: DSC07486.jpg]
07-04-2019, 07:55 AM #3
07-04-2019, 07:56 AM
[Image: DSC07487.jpg]
[Image: DSC07489.jpg]
[Image: DSC07490.jpg]
[Image: DSC07491.jpg]
[Image: DSC07493.jpg]
[Image: DSC07496.jpg]
[Image: DSC07497.jpg]
Paint thickness readings were taken. Obviously being painted the levels were noticeably higher than you would expect for original paint
[Image: DSC07498.jpg]
[Image: DSC07500.jpg]
[Image: DSC07503.jpg]
[Image: DSC07504.jpg]
[Image: DSC07505.jpg]
[Image: DSC07507.jpg]
I chose to use Meguiars M205 polish, a 3M polishing pad and backing plate and the Makita rotary. Each panel required 2 hits of this process to achieve the results i wanted the car to leave with for a stage 1 treatment. The defects remaining would require a step up in compound to remove, which would need a stage 2 correction treatment. As the defects that remained had the edges taken off them during the process applied here, this hugely changes the way natural light hits them, and as you will see as the car develops, this will still leave an exquisite finish to the vehicle
[Image: DSC07513.jpg]
[Image: DSC07515.jpg]
Starting on the front wing
[Image: DSC07518.jpg]
[Image: DSC07519.jpg]
[Image: DSC07523.jpg]
Moving onto the door
[Image: DSC07526.jpg]
[Image: DSC07531.jpg]
07-04-2019, 07:56 AM #4
[Image: DSC07536.jpg]
[Image: DSC07543.jpg]
[Image: DSC07545.jpg]
The rear wing
[Image: DSC07563.jpg]
[Image: DSC07568.jpg]
[Image: DSC07569.jpg]
[Image: DSC07570.jpg]
[Image: DSC07580.jpg]
The blades of the carbon spoiler had to be removed to allow the machine full access
[Image: DSC07584.jpg]
Moving round to the other side
[Image: DSC07593.jpg]
[Image: DSC07595.jpg]
[Image: DSC07598.jpg]
[Image: DSC07600.jpg]
[Image: DSC07601.jpg]
[Image: DSC07607.jpg]
Onto the passenger door
[Image: DSC07608.jpg]
[Image: DSC07615.jpg]
Polished side under LED light
[Image: DSC07619.jpg]
Unpolished side
[Image: DSC07621.jpg]
07-04-2019, 07:56 AM #5
The rear wing
Unpolished side
Passenger front wing had some lovely defects clearly visible
[Image: DSC07627.jpg]
[Image: DSC07628.jpg]
[Image: DSC07634.jpg]
Round to the bonnet and then front bumper
[Image: DSC07637.jpg]
[Image: DSC07638.jpg]
[Image: DSC07639.jpg]
[Image: DSC07643.jpg]
[Image: DSC07653.jpg]
[Image: DSC07649.jpg]
Then the A pillars and roof
[Image: DSC07677.jpg]
[Image: DSC07682.jpg]
The carbon spoiler was also machined
[Image: DSC07688.jpg]
[Image: DSC07689.jpg]
[Image: DSC07690.jpg]
[Image: DSC07691.jpg]
[Image: DSC07693.jpg]
Once all polishing was complete, and all panels had been IPA'd to remove polishing oils, out came the box of Do Luck stickers to return the original graphics the car was known for. Each sticker location was carefully checked to its original place
[Image: DSC07694.jpg]
[Image: DSC07698.jpg]
The glass was then cleaned using 3M Glass Cleaner
[Image: DSC07699.jpg]
07-04-2019, 07:56 AM #6
07-04-2019, 07:57 AM
The exhaust was polished inside and out
[Image: DSC07701.jpg]
[Image: DSC07702.jpg]
[Image: DSC07708.jpg]
Swissvax Cleaner Fluid was then applied by hand to the paint to prepare it for the wax application
[Image: DSC07711.jpg]
The chosen wax, was Swissvax Best of Show. Applied in a thin layer and buffed off after 15 mins
[Image: DSC07712.jpg]
The wheels, although really requiring a refurb, were polished up with NXT, ipa'd and sealed with Poorboys. Tyres were dressed with Endurance Gel
[Image: DSC07715.jpg]
The boot was hoovered and everything cleaned with APC
[Image: DSC07717.jpg]
[Image: DSC07719.jpg]
The interior was hoovered and dusted down
[Image: DSC07722.jpg]
[Image: DSC07725.jpg]
[Image: DSC07730.jpg]
[Image: DSC07731.jpg]
These were the final pictures after window seals and scuttle panel treated with Bumper Care
[Image: DSC07740.jpg]
[Image: DSC07746.jpg]
[Image: DSC07749.jpg]
[Image: DSC07750.jpg]
[Image: DSC07751.jpg]
[Image: DSC07755.jpg]
[Image: DSC07756.jpg]
[Image: DSC07758.jpg]
07-04-2019, 07:57 AM #7
[Image: DSC07763.jpg]
[Image: DSC07768.jpg]
[Image: DSC07773.jpg]
[Image: DSC07774.jpg]
[Image: DSC07775.jpg]
[Image: DSC07776.jpg]
[Image: DSC07778.jpg]
[Image: DSC07779.jpg]
[Image: DSC07780.jpg]
[Image: DSC07788.jpg]
[Image: DSC07791.jpg]
[Image: DSC07793.jpg]
[Image: DSC07794.jpg]
[Image: DSC07803.jpg]
[Image: DSC07808.jpg]
[Image: DSC07819.jpg]
[Image: DSC07822.jpg]
[Image: DSC07821.jpg]
[Image: DSC07830.jpg]
[Image: DSC07832.jpg]
07-04-2019, 07:57 AM #8
07-04-2019, 07:58 AM
[Image: DSC07841.jpg]
Finally the car was wrapped under a sheet to await Jamesy's arrival
[Image: DSC07844.jpg]
When he came, we both applied the Do Luck sunstrip, as best we could Smile This wasnt an easy task!
[Image: DSC07847.jpg]
These were the final pictures as the car was pulled outside to leave
[Image: DSC07848.jpg]
[Image: DSC07849.jpg]
[Image: DSC07850.jpg]
[Image: DSC07851.jpg]
[Image: DSC07853.jpg]
[Image: DSC07854.jpg]
[Image: DSC07855.jpg]
[Image: DSC07857.jpg]
[Image: DSC07858.jpg]
[Image: DSC07859.jpg]
It was a great pleasure, to work on the Do Luck Supra, and for Jamesy. He's a fantastic guy that will do the car proud, for us all to appreciate back in UK events.
Thanks for reading,
Christian
07-04-2019, 07:58 AM #9
Thanks for reading,
Christian
speedfreek
07-04-2019, 09:18 AM
Cracking work and what a lovely car! That paintjob is a bit special!
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
07-04-2019, 09:18 AM #10
[/SIZE]
(Current project)
Views 648
28-04-2021, 12:09 PM
Last Post by 350zLad
Views 440
10-03-2020, 03:45 AM
Last Post by sprinter2012
Replies 33
Views 2,008
25-07-2019, 03:58 AM
Views 1,080
05-09-2018, 01:37 AM
Last Post by Stoney
Views 1,015
10-03-2018, 12:31 PM
Views 1,112
28-08-2017, 11:49 AM
Last Post by ormi
Views 1,303
