My Car 3SGTE powered IS200
Well most people from LOC know my car, it had its first day out on Sunday to the Pod, but on the way the clutch let go so I was unable to get any runs up the 1/4 mile:mad:
I have ordered a stage 2 organic plate and stage 1 pressure plate to replace the failed one from FenSport. Should have that tomorrow:p I don;t know if the fly wheel is damaged yet but they aren't a lot on the 3SGTE.
It is running very rich (over fuelling) this will have to be sorted out ASAP, Toyota GT think it is just a air/fuel sensor, but for my piece of mind it is going to someone else for diagnosis, not sure who yet though.
Yeah should be a good do then.
I'd seriously suggest you get yourself a wideband AFR meter in the car though
looks good phil sorry to hear about the mishaps with the clutch
hopefully it's a quick and easy fix
Dan pointed me at your build thread on LOC and I've been watching it for a while, I like it a lot! Very original.
All 3S-GTE's overfuel a bit, it's Toyota's failsafe to stop detonation prior to them actually making a decent fuel computer. The engine you've got is from a Rev3 so it's MAP based rather than using an AFM so if it's overfueling past the stock AFR rates then your lambda sensor is most likely broken (which is the air/fuel mix sensor you mention in your first post). The sensor itself is hideously expensive from Toyota but there is an alternative supplier available. It's a simple diagnosis that can be performed with a multimeter, but I bet the sensor is a pig to get to in your car due to your exhaust manifold layout!
John showing the 3S-GTE knowledge, stick some picks up in the MR2 section
dan_harris looks good philsorry to hear about the mishaps with the clutch
Should TGT not be at least assisting with these charges?
