JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Need some help pricing up some work on my is200
Lewed_is200
10-12-2019, 10:16 AM
Hi everyone, now I have a few jobs on the car that I can't realy do, so I need some help working out how much ruffly it would cost to get the work done in a repituble garage.
Job 1) I have 2 reconditioned front calipers to replace the old f#***#g sticking ones, so how much should I be looking to pay to get them fitted and bled?
Job 2) I have a replacement center exhaust to replace the old one, now I have tryed to do this myself but the bolts holding it on the the cat part of the exhaust are compleatly corroded and so I can't get them off so would need a garage to remove old bolts and fit new center pipe with new bolts. So also how much would this work cost?
Job 3) also I have 3 new belts to go on which I also can't do which are the alternator belt and the a/c belt and the power steering belt. How much would this work cost?
Thanks for any help you guys can give.
Lewis.
Lewed_is200
10-12-2019, 10:16 AM #1
Lewis.
10-12-2019, 10:37 AM
I'd say half a days work there for all the jobs, about 4 hours labour
10-12-2019, 10:37 AM #2
10-12-2019, 11:27 AM
angle grind the bolts off and replace with new ones
the callipers you can get a kit of ebay for and wont take to long if you know what ur doing
ebay
all these jobs can be done by you and are fairly simple wiht a basic tool kit
10-12-2019, 11:27 AM #3
ebay
Lewed_is200
10-12-2019, 11:48 AM
Lexuspat angle grind the bolts off and replace with new ones
ebay
Yeh your right I could probably do the exhaust myself and the calipers I can fit myself but its the bleeding of the brake system after that I'm not to keen on as I've never done it before and the same goes for the belts.
How much would i be looking at for just the calipers? and Anyone no how to do the belts?
Thanks again.
Lewed_is200
10-12-2019, 11:48 AM #4
ebay
Thanks again.
10-12-2019, 12:09 PM
the actual callipers refurbed or new are extremely expensice and not worth it,
draper do a bleed system all you do is attatch a pipe to the nipple and pump the pedal as its a oneway valve so it bleeds it for you, then you can get out of the car and tighten the nipple up so easy to use ive just done my again today
draper bleed kit
10-12-2019, 12:09 PM #5
draper bleed kit
10-12-2019, 12:12 PM
also here a walk through guide for the belts
www.outlawjapclub.co.uk
10-12-2019, 12:12 PM #6
10-12-2019, 12:35 PM
If you use a brake like clamp (as you should) then remove the calliper you will probably get away without bleeding the system. Some people use a mole-grip instead of a dedicated clamp, just be careful about how much pressure you apply. Its an easy job on the IS200.
10-12-2019, 12:35 PM #7
Lewed_is200
10-12-2019, 12:51 PM
Lexuspat the actual callipers refurbed or new are extremely expensice and not worth it,
draper bleed kit
Cheers mate, yeh that sounds perfect. I got refurbed ones of ebay @ £90 each with the option to send my old ones back and get £30 back per caliper. So I'll get that bleeding kit and give it a go.
Cheers mate.
Lewed_is200
10-12-2019, 12:51 PM #8
draper bleed kit
Cheers mate.
Lewed_is200
10-12-2019, 12:53 PM
I'll give the belts ago aswell.
Cheers mate you may have just saved me £100's
Lewed_is200
10-12-2019, 12:53 PM #9
10-12-2019, 01:12 PM
That's what we are here for to help each other out
10-12-2019, 01:12 PM #10
Views 413
13-12-2023, 02:06 PM
Views 542
09-11-2023, 03:46 AM
Last Post by Dinho
Views 913
06-11-2022, 01:49 AM
Views 3,043
02-11-2022, 10:55 AM
Views 370
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,593
23-02-2022, 01:20 PM
Views 411
18-10-2021, 02:04 AM
Views 576
03-09-2021, 11:04 AM
Views 532
29-08-2021, 09:59 AM
Replies 35
Views 8,064
04-08-2021, 04:34 AM
Last Post by cjoseph
