Pages (17): 1 2 3 4 517 Next
Daniel N
11-03-2020, 12:25 PM
Greetings from Denmark.
I have a 2001 Lexus IS200 with a TTE charger kit (130mm pulley) and a larger intercooler than TTE standart and a blackbox from Patrik.
I've been reading a lot about the larger pulley question. And I would like a little more power.
I'm thinking a 140mm or 145mm pulley. I don't want to risk to much with a 160mm.
Would it be enough with a 140mm/145mm pulley and larger injectors or should I change other things? If so where can I buy the pulley and the right injectors?
Thanks a lot for any response.
Daniel
Daniel N
11-03-2020, 12:25 PM #1
Daniel
11-03-2020, 12:52 PM
145mm with a TTE Blackbox is perfectly safe, I was told by the guys on Euro LOC if you upgrade the injectors to the ones from a 1ZZ engine you can get 245hp easily without any other mods.
11-03-2020, 12:52 PM #2
Daniel N
11-03-2020, 09:03 PM
Thanks for the reply.
Sounds really great. Do you know where I can get a 145mm pulley and the 1ZZ injectors?
Daniel N
11-03-2020, 09:03 PM #3
S
12-03-2020, 08:06 AM
Daniel N Thanks for the reply.
Pulley - custom made
Injectors - eBay
S
12-03-2020, 08:06 AM #4
Injectors - eBay
12-03-2020, 08:15 AM
As above. But with regard to sourcing a pulley, there is a guy on Euro LOC that makes pulleys in various sizes. I'll see if I can find the PM that said who it was and let you know.
12-03-2020, 08:15 AM #5
Daniel N
12-03-2020, 09:11 AM
Okey guys thanks a lot. I see there's different sizes of injectors on Ebay for the 1ZZ engine. 520cc, 540cc 550cc, 700cc, 1000cc. Do you know which size?
Regarding the pulley thanks sprinter2012
Daniel N
12-03-2020, 09:11 AM #6
S
12-03-2020, 12:02 PM
Daniel N Okey guys thanks a lot. I see there's different sizes of injectors on Ebay for the 1ZZ engine. 520cc, 540cc 550cc, 700cc, 1000cc. Do you know which size?
They are all too big for what you need if your only going 140mm.
A lot of people say that the standard injectors are good enough if you aren't going "mad"
If I was you I'd get an AFR gauge and leave the standard injectors in and only upgrade them if the gauge shows your running lean.
S
12-03-2020, 12:02 PM #7
12-03-2020, 01:58 PM
Are you sure that's for 1ZZ not 1JZ?
It's the 1ZZ-FE in particular that you'd need, I just went through my old posts and found the info, the injectors you want are DENSO 23250-22040
To quote from the guys on Euro LOC, who are the kings of supercharged IS200s...
Quote:140mm pulley + 1zz-fe injectors + decat manifold should make about 230-240hp on the clutch
Also, the guy on there who makes the pulleys is under the name of 'Godfather'
12-03-2020, 01:58 PM #8
Daniel N
12-03-2020, 09:01 PM
Once again thanks a lot. I now know what to get. I will just have to decide if I'm going for bigger injectors or try to see if the injection of fuel is good enough on the standart injectors with an AFR gauge.
Daniel N
12-03-2020, 09:01 PM #9
phaebo
13-03-2020, 08:33 AM
like sprinter2012 said you will need the green 1zz-fe injectors.
they are around 250cc
phaebo
13-03-2020, 08:33 AM #10
Views 806
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 319
01-07-2022, 12:38 PM
Last Post by lexusdaydreaming
Views 543
14-09-2021, 07:43 AM
Last Post by P.Lindblom
Views 755
09-08-2021, 10:35 PM
Last Post by Jimbob-T-Lex
Views 432
26-07-2021, 11:20 AM
Last Post by reganlives
Views 463
30-03-2021, 03:26 PM
Views 402
13-03-2021, 05:38 PM
Last Post by deccie22
Views 666
17-09-2020, 03:53 PM
Last Post by gsitlv
