JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications High pitched whistling noise from charger inlet.
Steveolkinevel
13-10-2024, 09:42 AM
Hi every one, I've just completed my supercharger conversion on my is200, everything's working well I'm getting 4psi and she pulls well, I however have this incredibly annoying whistling noise on part throttle sounds like it's leaking boost through a small hole but it's not,
I closed off the bypassvalve on tick over and it will make the noise then as it starts to build boost slightly, I removed the air filter, noise still there, all the pipework to charger inlet, still there!
Now I'm stumped, anyone else have this problem? Makes the car sound rediculous and is sooo ****** loud!
Any help would be great,
ATB steve
Steveolkinevel
13-10-2024, 09:42 AM #1
ATB steve
13-10-2024, 03:22 PM
Have you got a video?
13-10-2024, 03:22 PM #2
Steveolkinevel
13-10-2024, 07:39 PM
Il get one tomorrow but how do I upload it, computers ain't my thing :bored:
Steveolkinevel
13-10-2024, 07:39 PM #3
23-10-2024, 08:36 AM
any update on the video so we can work out whats going on mate ?
23-10-2024, 08:36 AM #4
Steveolkinevel
23-10-2024, 02:20 PM
No mate, the charger has started rumbling so I removed it today and just stripped it down.
Steveolkinevel
23-10-2024, 02:20 PM #5
Steveolkinevel
06-11-2024, 08:27 AM
Ok I don't have to worry about the whistle anymore because after the charger rebuild it was running sweet, 15 miles later it committed suicide! So it's now been removed.
Steveolkinevel
06-11-2024, 08:27 AM #6
06-11-2024, 05:38 PM
Oh dear, what caused the failure?
06-11-2024, 05:38 PM #7
08-11-2024, 04:57 PM
Oh not good at all, but should be able to find another
sent from Admin HQ via tapatalk
08-11-2024, 04:57 PM #8
Steveolkinevel
10-11-2024, 05:44 PM
It seems that the rotors have moved on the shaft and drilled their way into the housing and wrecked the needle bearings and chewed the case to bits, there a poor design really as everything is just pressed on to the shaft and the needle bearings have no seat to keep them where they need to be.
I never removed or moved the rotors so I'm puzzled to how they have moved.... well only one has moved and the gears are still timed up and the shaft hasn't moved either.
O well these things are sent to try us, also had rear discs go on the same outing then my jack burst when I went to jack it up! Wtf! Ha ha
Match and some petrol any one?
Steveolkinevel
10-11-2024, 05:44 PM #9
Wayne
10-11-2024, 07:35 PM
they say it comes in threes..
Wayne
10-11-2024, 07:35 PM #10
Replies 168
Views 13,444
03-07-2023, 08:45 AM
Views 943
30-03-2022, 09:15 PM
Views 719
13-03-2022, 11:27 PM
Last Post by deccie22
Views 652
07-06-2021, 06:18 AM
Last Post by reganlives
Views 1,399
15-04-2021, 06:59 PM
Last Post by S
Views 924
24-11-2020, 07:54 PM
Last Post by Jon
Views 1,210
24-11-2020, 06:07 PM
Last Post by argyle dan
Views 1,347
14-08-2020, 08:51 PM
Views 1,744
04-08-2020, 07:12 AM
Last Post by lookatmybiceps
