JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications charger upgrade
charger upgrade
charger upgrade
liquidlazer
06-06-2020, 01:12 AM
Hey guys what size belts are you all using on your upgraded pulley for the charger.
150mm and 160mm respectfully
liquidlazer
06-06-2020, 01:12 AM #1
reganlives
06-06-2020, 01:23 AM
Sorry to hijack your thread but I'd love to know which belts to use for all really...
The standard pulley, and upgraded pulleys.
reganlives
06-06-2020, 01:23 AM #2
06-06-2020, 10:53 AM
5pk853 for 160mm pulley
06-06-2020, 10:53 AM #3
liquidlazer
06-06-2020, 11:25 AM
I am using 5pk 855 on 160mm pulley. But I tend to get some slip on high rpms
liquidlazer
06-06-2020, 11:25 AM #4
06-06-2020, 02:31 PM
Technically there is no one correct belt size for each pulley size, but a range, due to the tensioner. I've often used a few mm different to what other people use/recommend just cos I can get certain sizes a lot cheaper locally.
If you are slipping and tensioner is maxxed then you will certainly benefit from a shorter one.
06-06-2020, 02:31 PM #5
06-06-2020, 02:33 PM
Daniel N Oh and I'm running 5PK 828 belt with the 145mm pulley.
^^^ May be of some use.
06-06-2020, 02:33 PM #6
phaebo
06-06-2020, 10:40 PM
I use 5pk820 on a 145 mm pulley
I used to use a 5pk790 on the 130 mm pulley
I also got this from euro lexus owner club
TTE Riemenscheibe 130mm: 5PK790
Nachbau Riemenscheibe 140mm: 5PK810
Nachbau Riemenschiebe 150mm: 5PK830
Nachbau Riemenschiebe 160mm: 5PK855
phaebo
06-06-2020, 10:40 PM #7
reganlives
07-06-2020, 12:29 AM
Thanks guys. May be worthwhile making this a sticky...
reganlives
07-06-2020, 12:29 AM #8
Replies 168
Views 7,431
03-07-2022, 02:56 AM
Replies 26
Views 1,240
26-04-2021, 11:42 AM
Last Post by lexusdaydreaming
Views 391
30-03-2021, 03:26 PM
Views 361
13-03-2021, 05:38 PM
Last Post by deccie22
Views 733
15-04-2020, 01:11 PM
Last Post by S
Views 494
25-11-2019, 02:05 PM
Last Post by Jon
Views 667
25-11-2019, 12:18 PM
Last Post by argyle dan
Views 886
15-08-2019, 03:02 PM
