charger belt slipping?
Hi All, only had my charger fitted for a few months now, problem is,sometimes when i go to put my toe down it hesitates. Now i dont know if its down to the belt slipping or a fueling issue. I'm running a 800 belt at the moment, but cant find a 790 anywhere only a 788,would that be ok?. Or could it be the FCD, any help would be great, as it is b***dy annoying. :cursing:Cheers
A slightly shorter belt is always a help.
But seems more ecu to me. What's it set on!
Hmm normally about right.
I'd try a new belt but I'd suggest getting one of Patriks black boxes as well.
I'll see if i can squeeze a 788 on it, then i'll try patrik and see if he's got any of his black boxes left. I need to sort something out as it's driving me mad. Cheers
A 788 belt will not fit.
I got a 5PK790 belt from Wood Auto Supplies. I think they need to special order it and you take a hit on the delivery charges but they got me one no problem. Very easy to deal with too.
http://www.woodauto.com/Component.aspx?Ref=5PK790
cheers for that, wood auto don't have any in stock at the moment ,so i'll give them another try at the start of next week.
argyle dan cheers for that, wood auto don't have any in stock at the moment ,so i'll give them another try at the start of next week.
Hi Rob, I have managed to source a 5pk790 (which i am waiting for now) and one of patrik's black boxes, so i will see how it behaves after i change them round, can't be any worse!. Anyway got a new problem, EML has come on with code P0420, which i believe is the O2 sensor behind the cat. Its a 200 cel cat which has only been on for 10 weeks. Not happy .
