JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Any Ideas
Any Ideas
Any Ideas
rosey1955
02-08-2017, 03:18 PM
Whilst driving around in my IS200 I heard, what can only be described as a loud bang from the underside of the near side. I stopped shortly afterwards to take a look but couldn't see anything wrong. I wound the nearside window down and drove along at slow speed, where I heard a constant metallic continual clicking noise which got faster if I increased my speed and vice versa if i travelled more slowly.
I have now jacked up the car and spun the rear wheel, where I could hear the noise again (on every revolution of the wheel)
It seems to be coming from inside the rear disc where the handbrake adjustment is. Before I have a more in depth look, has anyone had a similar problem, or have any idea what it could be? Huh
rosey1955
02-08-2017, 03:18 PM #1
02-08-2017, 03:21 PM
Does your handbrake still work?
02-08-2017, 03:21 PM #2
Demon
02-08-2017, 03:22 PM
Im guessing wheel bearing? But that is a complete guess, someone might be able to shed more light on the subject? Is the wheel hard to turn?
Jason
The 'Demon' is on its way :Shooting:
Now driving a Sh!tbox Sad
Smurf SOLD
Outlaw No: 016 Cool
Demon
02-08-2017, 03:22 PM #3
Jason
Smurf SOLD
Outlaw No: 016 Cool
rosey1955
02-08-2017, 03:25 PM
Sparky, First impressions show the H/Brake to be working
Demon, No play in the wheel bearing (movement top to bottom or side to side)
rosey1955
02-08-2017, 03:25 PM #4
rosey1955
02-08-2017, 03:35 PM
The wheel also appears to be free to rotate....
rosey1955
02-08-2017, 03:35 PM #5
rosey1955
05-08-2017, 08:46 AM
I have today removed the disc from the rear wheel and examined the handbrake mechanism. Both shoes were in place as were the springs on both sides. To my horror I saw a 'bent' metal bar wedged close to the adjuster. This bar is about 10mm wide and is shaped (side on) like a letter E.
The outer edges appeared rough (as if spot welded to the back plate). Upon close inspection I saw two markes on the back plate just underneath the handbrake cable.
As such i examined the other side and found that the metal bar had also come adrift and was wedged to one side of the brake shoe.
I went along to Lexus in Norwich and spoke with one of their mechanics who identified it as the holder for the handbrake cable. He advised me that I had a number of options, run without them, spot weld them back into place, or purchase a new back plate which would also necessitate the removal of the hub!!!
Has any one else experienced this?
rosey1955
05-08-2017, 08:46 AM #6
05-08-2017, 08:54 AM
That sounds very odd ! I wonder if a previous owner/mechanic had done something to the car that helped cause this to happen ? :confused1:
05-08-2017, 08:54 AM #7
rosey1955
05-08-2017, 09:09 AM
If I were to replace the back plate it would cost the earth. In any case the back plate is not damaged or rusty.
Stevie' as you point out it does appear a mystery. I did wonder whether my mechanic whom I use, had overtightened the handbrake adjustment, but even so would doubt that it would cause the plates to fall off/break off.
rosey1955
05-08-2017, 09:09 AM #8
05-08-2017, 09:30 AM
Can you not get some bits from a breaker's to fix it ?
05-08-2017, 09:30 AM #9
rosey1955
05-08-2017, 09:31 AM
Just as a matter of interest does anyone know where I can locate one of those user manual exploded views of the rear handbrake mechanism (with disc removed)?
rosey1955
05-08-2017, 09:31 AM #10
Views 634
03-08-2020, 03:51 PM
Last Post by sprinter2012
