JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Car sometime's won't start first time...any ideas?
29-06-2018, 08:04 AM
It's something the car has always done, maybe once every couple of weeks if that, I'll go to start the car, the engine turns over a couple of times, then all of a sudden it speeds up as if all the resistance has been taken away and then won't start.
It always starts second time without fail, and I only remember it ever happening as I'm leaving work in the evening, never in the morning on the way to work, or any other time of day for that matter.
My commute to work is plenty long enough to let the engine warm up fully, the spark plugs were changed last month, air filter is clean, battery is nearly new etc.
So what could it be? Imobiliser problem maybe?
I'm sure I read on the other side that another guy had this problem, and it was suggested that it may be the auto-choke sticking?
i.e. It was still set in the 'wam engine' position from when it was last turned off.
(I may just be remembering that completely wrong though)
It makes no difference how long I wait after turning the ignition on, however I have found blipping the throttle pedal before trying to start seems to help?
I'm just confused by it, as it happens so infrequently. Seems to only happen when leaving work, and then always starts second time?
:confused1::confused1:
29-06-2018, 08:04 AM #1
29-06-2018, 08:29 AM
Well you don't have an auto choke that can stick so you can ignore that. Could be a funky water temp sensor, I dunno if the IS uses seperate ones for the dash gauge and the ECU like older Toyotas do. That played havoc with my cold starting when mine was rotten.
29-06-2018, 08:29 AM #2
dodgydave
29-06-2018, 08:32 AM
Funny, I have exactly the same problem. It doesn't do it very often but is always when leaving work late afternoon. I remember someone on the other side saying that you need to press the excelerator after turning the ignition on as this sets the throttle or something. I do do this if I remember and it does seem to work, when I use this technique it seems to always start.
dodgydave
29-06-2018, 08:32 AM #3
greeny
29-06-2018, 08:44 AM
Sounds like a leaky fuel return valve, fuel is slightly air lockin but then being pulled through,
[SIGPIC][/SIGPIC]One chance in life - LIVE it to the full
:drink: :thumbup:
greeny
29-06-2018, 08:44 AM #4
:drink: :thumbup:
29-06-2018, 08:46 AM
dodgydave Funny, I have exactly the same problem. It doesn't do it very often but is always when leaving work late afternoon. I remember someone on the other side saying that you need to press the excelerator after turning the ignition on as this sets the throttle or something. I do do this if I remember and it does seem to work, when I use this technique it seems to always start.
Odd that we both get it at the same time of day, it's really got me stumped!
And like you say, I don't remember it ever doing it after dabbing the throttle after turning the ignition on...hmmm.
Edited 10-08-2011, 06:21 PM by sprinter2012.
29-06-2018, 08:46 AM #5
Bonney
29-06-2018, 11:23 AM
Mine did this a few times the other week, I put it down to dirty or worn plugs.
Bonney
29-06-2018, 11:23 AM #6
RichyUK
29-06-2018, 12:28 PM
mine does it too!
RichyUK
29-06-2018, 12:28 PM #7
mine does it too!
04-07-2018, 08:30 AM
Seems this is a common problem, I think from this thread and the one I posted on the other side I've had over 10 people claim to have the same issue.
A couple of their responses were...
"Before I used to put the key in and try to start the car straight away, when I tried to start to engine it used to turn but some time the engine didnt start fully as if the engine was flooded. As I said before the 10 second wait helped alot, it was not the immobiliser as the engine turned and sounded like it tried to start (but it didnt sound "painful") and the immobiliser light was not flashing. "
"My IS200 does this now and again, it is now 9 years old. I just switch it off and turn the key on again, leave for a few seconds then start it. It has always started the second time."
"My mate has also had this problem with his IS200, for the last 8 years!
He's had lexus look at it and it only happens now and again, they told him it was the throttle body, the choke side of things, but wanted a small fortune to change it.
Always starts second time, just one of them things. "
Mine did it again yesterday, second time in a week. And I'd done my routine of tap the throttle and thought I'd just let it sit for a while after turning the ignition on too. But nope, still didn't help.
I'm so sure that its temperature related, as it NEVER does this anywhere except work, and only when I leave in the evening. Sometimes I go out for lunch at 2ish, and it's only ever done it once then.
So I'll be interested to see what happens when the cooler weather arrives...
04-07-2018, 08:30 AM #8
JonPowellDJ
04-07-2018, 08:50 AM
Yeah mine does this sometimes! It's completely random though.
JonPowellDJ
04-07-2018, 08:50 AM #9
04-07-2018, 09:01 AM
The occassions mine happens could be slightly biased though, in that it I only use my car to go to and from work. And then twice a week to training about 10minutes after I arrive home from work.
So its only my journey home from work where its left for around 8 hours till the next start and probably doesn't fully coll down like it oes overnight...I may test it at the weekend, by waking up at my normal work time, drive around for 10 minutes, and then park it up and try to start it after the equvalent of my working day.
04-07-2018, 09:01 AM #10
Views 401
04-08-2019, 10:02 AM
Last Post by sprinter2012
Views 736
23-07-2019, 06:57 AM
Views 882
20-06-2019, 03:53 PM
Last Post by Mr Reman
Views 448
08-05-2019, 01:20 AM
Last Post by jomo
Replies 27
Views 1,617
02-05-2019, 12:59 AM
Views 760
23-01-2019, 12:22 PM
Last Post by reco2k
Replies 26
Views 1,431
09-09-2018, 07:16 AM
Last Post by Stoney
Views 820
07-09-2018, 12:41 PM
Last Post by clossie
Views 781
12-07-2018, 05:26 AM
Views 295
04-07-2018, 09:46 AM
