JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Boost gauge install
Boost gauge install
Boost gauge install
marko45
05-11-2020, 01:17 AM
I own a supercharger for a few months and I would like to install a boost gauge.
Which gauge do the job without spending a lot of money?
And also, do you know where I can find a tuto with pics that explains how to install it, especially the sensor. I have never done it.
Thx
marko45
05-11-2020, 01:17 AM #1
Thx
05-11-2020, 06:08 AM
Any gauge is good really mate as long as it's not too cheap. But the good ones are Defi/AEM/HKS. But a manual boost gauge is good. It depends if you want manual or electronic.
Either way you'll have to tap into a vacuum line (either to run a hose to a manual gauge, or a hose to a sensor on an electronic gauge) which would be around the throttle body/plenum area.
Pics:
[Image: DSCF2536_edited.jpg]
[Image: DSCF2533_edited.jpg]
Note: I didn't take the above pictures, Chris (Bandit on here) took them so please give him credit for the pictures.
You just put a t piece in the hose, then where the clear hose comes off, goes to either your sensor or the hose.
Then it's just feeding the hose/wire through one of the main rubber grommets in the firewall, through and up your dash.
05-11-2020, 06:08 AM #2
Pics:
05-11-2020, 07:53 AM
Olis given you the best pics, youll struggle to find a gauge that does the low pressures of the charger, as most are 2bar and so the needle wont move much at 0.3bar
05-11-2020, 07:53 AM #3
marko45
05-11-2020, 08:46 AM
It is just for fun, i know the needle will not morve that much but it dors not mater.
Is there any advantages to get an analog or a digital gauge ? I have seen the AEM 30-5132M analog gauge but i do not understand what they call the sensor, is it the vacuum line on the pics above or is it an extra sensor ?
Sorry but i do not know any thing on this subject. I do not really understand where everything has to be plugged in the case of an analog and digital gauge.
marko45
05-11-2020, 08:46 AM #4
05-11-2020, 10:09 AM
A mechanical gauge the tube goes all the way to the gauge and a little tube inside the gauge expands to move the needle.
In an electrical gauge with a sensor, the pipe goes to the sensor then the sensor sends a signal to the gauge and a motor moves the needle
05-11-2020, 10:09 AM #5
marko45
05-11-2020, 10:54 AM
In the mechanical one, the tube goes from the gauge to the vacuum line?
marko45
05-11-2020, 10:54 AM #6
05-11-2020, 12:41 PM
Yep mate
05-11-2020, 12:41 PM #7
Yep mate
marko45
06-11-2020, 12:20 AM
Thanks, it a bit clearer now.
marko45
06-11-2020, 12:20 AM #8
03-12-2020, 09:38 AM
did you get it fitted mate got any pics of it done ?
03-12-2020, 09:38 AM #9
Views 1,764
05-07-2023, 05:08 AM
Last Post by damtrx
Views 461
21-12-2022, 02:57 AM
Last Post by lexusdaydreaming
Views 355
21-03-2021, 07:12 AM
Views 277
28-01-2021, 10:29 AM
Views 754
25-06-2020, 11:37 AM
Views 270
28-04-2020, 01:27 PM
Views 266
07-03-2020, 12:49 PM
Views 764
30-06-2019, 11:49 AM
Views 640
04-09-2018, 02:44 AM
Last Post by P.Lindblom
