JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Boost gauge
Boost gauge
Boost gauge
196
20-03-2021, 11:03 PM
Hi I installed my sc and boost gauge. The boost gauge is reading at 20 in.hg Any help would be great I may have missed something.
lexusdaydreaming
20-03-2021, 11:03 PM #1
21-03-2021, 05:11 AM
20 inHg being 9psi? That's about right if you're running a larger pulley.
21-03-2021, 05:11 AM #2
21-03-2021, 05:38 AM
On my gauge it has 0 to 30 psi and below the 0 psi it goes from 0 to 30 vac in hg. I think it's staderd pulley but I am not sure.
lexusdaydreaming
21-03-2021, 05:38 AM #3
196
21-03-2021, 05:44 AM
I read up on boost gauge and cars are ment to idle at 20 in hg untill boost is ready but with the charge I thought it was constant maybe because I didn't drive it it didn't read my psi. Once I sort the rest out I will test again.
lexusdaydreaming
21-03-2021, 05:44 AM #4
phaebo
21-03-2021, 05:49 AM
You will only see boost when you fully press the gas pedal. When driving. When you full press the gas the bypass closes and then you start to build boost.
The standard pulley will give you 0,34 bar boost
phaebo
21-03-2021, 05:49 AM #5
21-03-2021, 06:42 AM
When the throttle is shut. The engine is sucking so you should be down there
21-03-2021, 06:42 AM #6
21-03-2021, 07:12 AM
Ahh ok guys thanks all try running it tomorrow.
lexusdaydreaming
21-03-2021, 07:12 AM #7
Views 1,764
05-07-2023, 05:08 AM
Last Post by damtrx
Views 461
21-12-2022, 02:57 AM
Last Post by lexusdaydreaming
Views 277
28-01-2021, 10:29 AM
Views 485
03-12-2020, 09:38 AM
Views 754
25-06-2020, 11:37 AM
Views 270
28-04-2020, 01:27 PM
Views 266
07-03-2020, 12:49 PM
Views 764
30-06-2019, 11:49 AM
Views 640
04-09-2018, 02:44 AM
Last Post by P.Lindblom
