JapCarForum Cars, Cars, Cars! Wheels & Tyres Understanding Wheel Offset
17-08-2016, 08:45 AM
When changing the wheels on your car for a different sort, the question of wheel offset is an important one in terms of making sure the new wheels will fit correctly (i.e. that they will neither stick out too far so that they extend beyond the arches, nor that they will foul the inner side of the wheel arch).
There's an article, with some diagrams, explaining wheel offset here. The diagrams show wheels with a positive offset, i.e. wheels whose mounting hub is closer to the outside than the centreline. It's also possible to have wheels with a negative offset, i.e. whose mounting hub is closer to the inside than the centreline.
There's a useful calculator here which you can use to show how differing offsets will affect how the wheel sits.
17-08-2016, 08:45 AM #1
17-08-2016, 10:24 AM
excellent info Stevie
17-08-2016, 10:24 AM #2
D1 RWD
24-08-2016, 02:10 PM
an offset can make or break the look of a car et40 =Blush et-5 =Confusedcared: and depending on the car et10-15 =:thumbup1:
i personally run staggered fitments 17" /9j et9 on the fronts and 18"/9.5j et12
ive actually wanted to ask whats the pcd of a altezzea as im considering keeping my SSR sp1's to put on an altezza but wasnt sure if theyd fit.
arch rolling is also well worth considering to get the wheel to fit "just right " in the arch, and i use a guy called phil who runs a firm called archenemy with various agents around the country.
so do you think id be able to squeeze me wheels under altez archs ???
[Image: 04092009856-1.jpg]
EVOLUTION....
D1 RWD
24-08-2016, 02:10 PM #3
EVOLUTION....
24-08-2016, 10:37 PM
PCD of an Altezza/IS200 is 5 x 114.3.
No, sorry, those low offsets won't work, they'll stick out a long way (unless you widen the arches etc). The standard factory wheels are ET50 !
24-08-2016, 10:37 PM #4
D1 RWD
25-08-2016, 12:24 AM
et50 !!!! blimey, so to get them on id need an extra 38mm of arch space.... ohh that aint gonna happen.
can you buy over fenders for altezza's ? or a wide arch kit ?
EVOLUTION....
D1 RWD
25-08-2016, 12:24 AM #5
EVOLUTION....
25-08-2016, 02:34 AM
D1 RWD et50 !!!! blimey, so to get them on id need an extra 38mm of arch space.... ohh that aint gonna happen.
Well you probably wouldn't need quite that much space, the standard ET50 wheels don't come right out to the edge of the arch. You can get some wide arch kits, I'll have a look around.
25-08-2016, 02:34 AM #6
Views 382
01-03-2023, 07:03 AM
Views 610
15-03-2021, 05:14 AM
Last Post by Morango
Views 746
04-06-2020, 11:08 PM
Last Post by purplewitch
Views 615
17-05-2020, 12:17 PM
Last Post by Colin G
Views 743
24-12-2019, 09:51 AM
Views 1,179
25-06-2019, 07:38 AM
Last Post by Mr Reman
Views 993
06-01-2019, 03:49 PM
Views 593
15-09-2018, 03:34 PM
Last Post by sprinter2012
