JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Had the IS200 MOT'ed and fitted LE grille
kam05
30-08-2016, 11:34 PM
Had the IS200 MOT'ed on Saturday and
...it passed!!! No advisories issued! My IS200 is now 9 years old and has 127k on the clock. These cars are built to last.
Also, I fitted a LE grille to my car, which I got for free on LOC (thanks to Eddieblock, Eddie if you read this thanks once again for this). Some pics below:
OEM 3 bar grille (as my car is a 2000 model it orginally came with a 4 bar grille):
[Image: DSC00218.jpg]
OEM 3 bar grille vs LE grille:
[Image: DSC00219.jpg]
OEM LE grille on car:
[Image: DSC00220.jpg]
Kam
kam05
30-08-2016, 11:34 PM #1
Kam
30-08-2016, 11:38 PM
Great news that it passed, and the grille is looking good :thumbup:
30-08-2016, 11:38 PM #2
30-08-2016, 11:45 PM
Good news:thumbup1: another year hope fully of free driving except petrol and maybe a service...
30-08-2016, 11:45 PM #3
Cous3
31-08-2016, 02:57 AM
That grill is miles better than the OEM one. I've seen one sprayed the same colour as the car and it looked very nice.
Good news with your MOT @127K that is brilliant!!
Had mine done on Friday @ 60K, passed with HIDs, advisory note for the tyre valves slightly perishedConfusedhock: Tyre wear in 1 year for about 10K miles was 1mm all roundConfusedhock: All tyre wear is even (run at 38psi), which goes to prove that Tony Bones @ WiM knows his stuff.........Cheers Tony!:thumbup1:
Keith
Cous3
31-08-2016, 02:57 AM #4
Keith
31-08-2016, 03:50 AM
Grille looks great - much better than standard Smile
Great news about the MOT too, got mine on Thursday so hope it flies through as well! Actually reminds me I need to swap out my HIDs or I'm going to end up with another set of standard headlight bulbs......
31-08-2016, 03:50 AM #5
31-08-2016, 03:55 AM
parthiban Great news about the MOT too, got mine on Thursday so hope it flies through as well! Actually reminds me I need to swap out my HIDs or I'm going to end up with another set of standard headlight bulbs......
Why ? Your HIDs should pass the MoT fine as long as the beam pattern is ok. What has happened before ?
31-08-2016, 03:55 AM #6
31-08-2016, 04:22 AM
steviewevie Why ? Your HIDs should pass the MoT fine as long as the beam pattern is ok. What has happened before ?
Was fine up until last year, but in last year's MOT the beam pattern with the HIDs didn't pass (they said something about getting a new machine) so they swapped in some standard bulbs to make the car pass.
31-08-2016, 04:22 AM #7
31-08-2016, 09:56 AM
Hmm, hope my local MoT stations don't get a new beam-testing machine then !
31-08-2016, 09:56 AM #8
31-08-2016, 11:44 AM
steviewevie Hmm, hope my local MoT stations don't get a new beam-testing machine then !
Should be safer with the smaller independents as they're less likely to buy expensive new machines!
Either way might be a good idea to take along a set of standard bulbs in the glovebox just in case, as it would be better to swap them out rather than risk failing or getting an advisory Smile
31-08-2016, 11:44 AM #9
spikes
31-08-2016, 12:59 PM
nice to hear car passed its MOT :thumbup:
spikes
31-08-2016, 12:59 PM #10
Views 413
13-12-2023, 02:06 PM
Views 545
09-11-2023, 03:46 AM
Last Post by Dinho
Views 925
06-11-2022, 01:49 AM
Views 3,044
02-11-2022, 10:55 AM
Views 371
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,599
23-02-2022, 01:20 PM
Views 416
18-10-2021, 02:04 AM
Views 577
03-09-2021, 11:04 AM
Views 534
29-08-2021, 09:59 AM
Replies 35
Views 8,069
04-08-2021, 04:34 AM
Last Post by cjoseph
