JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza fitting a hks FCD- a guide or directions??
Pages (4): 1 2 3 4 Next
Joff
09-09-2016, 04:49 AM
hi all,
my hks FCD has now arrived just wondering if anyone can help me out with any directions to fitting it?
thanks
Joff
09-09-2016, 04:49 AM #1
hi all,
thanks
09-09-2016, 04:53 AM
The colours are to be fitted as red to red, black to black. then yellow to green, and white to yellow.
Is this what you mean?
09-09-2016, 04:53 AM #2
Joff
09-09-2016, 05:01 AM
thanks
has any one got any photos? showing which wires they are ment to go to? my wiring is bit messy! dont want to connect it up to wrong wires etc
Joff
09-09-2016, 05:01 AM #3
thanks
09-09-2016, 05:06 AM
Hold fire Joff i think your have someone that can supply photos along soon
09-09-2016, 05:06 AM #4
09-09-2016, 05:11 AM
This is how i wired mine up mate,
Black wire from FCD into block E6 connected to a White wire with a black stripe,
Red wire from FCD into block E2 connected to a Black wire with a Red stripe
The fcd White and yellow wire go to Block E5 which was a Green wire with a Red stripe and cut this wire, the fcd yellow wire conected towards the ECU and the White fcd wire connected to the wire going away from the ecu, both connected to the Green wire with the Red stripe?
I've got a pic somewhere from when i did it so will see if i can find it for you? Smile
edit found it, was a pic from DJ WOZZA that he sent me a while back?
[Image: HKSFCD.jpg]
Edited 21-10-2009, 03:02 PM by Bandit.
09-09-2016, 05:11 AM #5
[Image: HKSFCD.jpg]
Joff
09-09-2016, 05:15 AM
thanks both for the help! yeh if you can get a pic that would help me loads!!!!!:biggrin:
Joff
09-09-2016, 05:15 AM #6
09-09-2016, 05:17 AM
Does this help
There are pics further down the thread.
http://www.is250.co.uk/forum/lofiversion...60096.html
09-09-2016, 05:17 AM #7
Does this help
Joff
09-09-2016, 05:29 AM
my wirings abit different to that pic i think!:S
do i just cut the wire and put it into fcd and then just tape up the loose end or do i need to cut wire and 'join ' it in?
Joff
09-09-2016, 05:29 AM #8
09-09-2016, 05:30 AM
just posted the same pic above :lol:
My old is200's on that topic :crying:
09-09-2016, 05:30 AM #9
09-09-2016, 05:35 AM
My wiring was different too when i did mine, and was a bit of a pain to figure out, but with a lot of help from Stav,, i sorted it out..
On mine the White and yellow FCD wires went to Block E5 which was a Green wire with a Red stripe and i cut this wire,
Then the yellow wire from the FCD connected towards the ECU and the White wire coming out of the FCD connected to the wire going away from the ecu, both connected to the Green wire with the Red stripe?
So you do need to cut just one wire! Smile
09-09-2016, 05:35 AM #10
Views 520
25-06-2021, 08:14 AM
Views 234
01-07-2020, 04:42 AM
Views 734
09-01-2019, 12:06 PM
Last Post by S
Views 436
05-11-2018, 01:33 PM
Last Post by Jimbob-T-Lex
Views 874
13-07-2018, 01:11 PM
Last Post by Phil01
