How too......IS200 oil and filter change.
well heres the last how too oil and filter change
remove the sump plug 14mm
now for the oil filter the best way to get at it is through the n/s front wheel arch area
i'm a cheat i have the propper filter tool at my work makes it easyer
heres my wee stubby ratchit ideal for this job
the filter is removed through the space you just had your arm up
you fit your new filter in the reverse order
remember and fit a new sump plug washer before fitting the sump plug tighten up and fill with oil job done.
sorry for the pic size
the car used for the demo in the three how toos was my own.
i am a tec and have been for a while!!you do the following at your own risk.
excellent write up mate
cheers again mate will try and do more.:thumbup:
Bloomin hek, pictures are mahooooooooosivehock: even across my 2 19" monitors they dont fit:laugh:.....Nice write up mate, gonna be changing mine soon!
James S What can I use to get the filter off? Do I need to shell out for the proper tool??
:blink:
:blink:
Another daft thing that works to remove the filter is a leather belt?(one to hold your jeans up?) make a loop with the belt, slip it over the filter pull it tight and with the loose end wrap it over the filter and pull, if you do it right it'll turn the filter using the buckle and belt for grip :laugh:
Or if you really want to save money a screwdriver hammered through the filter.................
