JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! How To Change A Front Caliper on a Lexus IS200
03-10-2016, 06:09 PM
1) right jack the car up remove the wheel(the side you are changing the caliper)
2)clamp the flexi off you can use mole grips(stops you loosing all the fluid)
3)slacken the brake flexi off(14mm)
4)remove the two 14mm bolts that hold the caliper to the pad housing
5)pull the caliper away once clear of the pads turn anti clock wise to unscrew caliper from flexi
6)while in bits check pads are free and slides are ok
7)screw new caliper to the flexi(dont fully tighten at this stage)
8)fit caliper to pad housing and tighten up the two 14mm bolts now you can tighten up the flexi
9)undo the mole grips on the flexi now this req two people
10)second person goes in the car while you slacken the bleed nipple(use a small hose on the nipple and put the hose in too the bottle saves mess)
11)make sure you have plenty of brake fluid and get the person in the car to pump the pedal approx 10 times
12)ON THE LAST PUMP HOLD THE PEDAL DOWN and tighten the nipple
13)check the pedal feel put wheel back on job done!!!!!
REMEMBER PEDAL MUST BE HELD DOWN WHEN YOU TIGHTEN THE NIPPLE!!!!!
:thumbup::thumbup:
03-10-2016, 06:09 PM #1
:thumbup::thumbup:
04-10-2016, 05:30 AM
:thumbup1: Good one Ormi
04-10-2016, 05:30 AM #2
Views 203
13-12-2022, 05:57 AM
Replies 46
Views 7,506
16-03-2022, 12:02 AM
Last Post by Emissary
Views 851
10-09-2021, 01:07 PM
Views 388
21-04-2021, 09:36 PM
Last Post by Zempify
Views 1,059
02-02-2021, 11:40 PM
Replies 25
Views 4,786
18-08-2019, 06:32 AM
Last Post by Johny47
Views 549
24-01-2019, 02:06 PM
Views 2,080
03-10-2018, 08:33 AM
Views 880
04-09-2018, 10:45 AM
