JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza My Solution To Driving An Is200 In The Snow
kam05
09-11-2016, 04:22 AM
1. Buy 5 bags of sand and put them in the boot (I've also got a shovel in the boot as well to dig myself out if necessary):
[Image: DSC00263.jpg]
2. Drop the tyre pressures on the rears:
[Image: DSC00264.jpg]
Might be helpful to others?
kam05
09-11-2016, 04:22 AM #1
09-11-2016, 04:33 AM
That will work, however on normal wet roads I was carrying about the same weight and the front went very light indeed round corners, something to watch out for.
09-11-2016, 04:33 AM #2
09-11-2016, 06:18 AM
and if you have a cat buy some extra cat sand and you can use it later when the snow has gone
09-11-2016, 06:18 AM #3
Views 413
13-12-2023, 02:06 PM
Views 542
09-11-2023, 03:46 AM
Last Post by Dinho
Views 913
06-11-2022, 01:49 AM
Views 3,043
02-11-2022, 10:55 AM
Views 370
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,593
23-02-2022, 01:20 PM
Views 411
18-10-2021, 02:04 AM
Views 576
03-09-2021, 11:04 AM
Views 532
29-08-2021, 09:59 AM
Replies 35
Views 8,064
04-08-2021, 04:34 AM
Last Post by cjoseph
