JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 140mm And 150mm Supercharger Pulley Upgrade
19-05-2017, 06:26 PM
I was surfing the EU LOC and quite a few members, who have TTE supercharges, have swapt their pulley with a larger one (140 mm and 150mm). They have raised the boost pressure between 0.45 and 0.5 bar. They also state that they did not have any problems none of them! Is this possible? I thought that IS200 cannot handle more boost than 0.4bar, as it has been stated in many posts. I asked the members how is it possible to have a reliable engine and they answered that with a proper engine management and without reving the engine at high rpm all the time no problem should exist.
19-05-2017, 06:26 PM #1
19-05-2017, 06:38 PM
Yes you are correct mate, they stated that they had an Apexi or Haltech ecu, larger intercooler and other fuel ejectors. But apart from that everything worked ok. One of them stated only that the temperature increases significantly and that the oem battery needs replacement because it might melt. It happened to him.
19-05-2017, 06:38 PM #2
22-05-2017, 02:18 PM
dimis Yes you are correct mate, they stated that they had an Apexi or Haltech ecu, larger intercooler and other fuel ejectors. But apart from that everything worked ok. One of them stated only that the temperature increases significantly and that the oem battery needs replacement because it might melt. It happened to him.
The under bonnet temps on my car were very high, infact the battery got some heat wrap to protect it. The problem was solved by removing the rubber seal at the bottom of the bonnet that seals the rear of the engine bay and lifting the bonnet up on washers, it looks a bit different but does a fantastic job of keeping temps down under the bonnet.
22-05-2017, 02:18 PM #3
23-05-2017, 08:14 AM
Do you have any pics to post to have an overall view?
23-05-2017, 08:14 AM #4
23-05-2017, 08:43 AM
[Image: DSCF0009.jpg]
Not the best photo.
Zoom version
[Image: DSCF000911copy.jpg]
Edited 04-07-2009, 12:32 PM by FirebirdPhil.
23-05-2017, 08:43 AM #5
Not the best photo.
Zoom version
23-05-2017, 11:18 AM
Why did you have very high temps? Is you car also supercharged? Have you done any interesting mods?
23-05-2017, 11:18 AM #6
23-05-2017, 01:04 PM
Errrrr yea full 3sGTE conversion, running 300BHP and big turbo.. Sorry I have changed my user name from LOC it used to be yeldarb.
23-05-2017, 01:04 PM #7
23-05-2017, 01:35 PM
2tongues Errrrr yea full 3sGTE conversion, running 300BHP and big turbo.. Sorry I have changed my user name from LOC it used to be yeldarb.
Now we know who you are :lol::lol:
23-05-2017, 01:35 PM #8
23-05-2017, 01:36 PM
Ooops, I know you from LOC with the nikname yerlab. You were the one who went to Egypt for holidays. Sorry mate.
23-05-2017, 01:36 PM #9
25-05-2017, 11:32 AM
No problems at all. Sorry to confuse, but it is in my "welcome" thread.....
25-05-2017, 11:32 AM #10
Views 804
29-08-2022, 03:48 PM
Views 1,196
29-08-2021, 12:58 PM
Replies 140
Views 13,353
05-03-2021, 02:51 PM
Last Post by Rolex
Views 362
27-12-2020, 08:44 PM
Last Post by Ste176
Replies 32
Views 2,836
07-09-2020, 04:37 PM
Last Post by sprinter2012
Views 587
31-08-2020, 08:38 AM
Views 1,830
19-08-2020, 05:50 PM
Last Post by Lance79
Views 877
01-08-2020, 06:24 AM
Replies 31
Views 3,372
23-07-2020, 08:31 PM
Views 558
19-07-2020, 03:46 PM
