IS200 SC custom made induction kit
Pictures say more than 1000 words:wink:
modular process
All from the bottom
The Apexi dry filter behind the fender
The whole is composed of:
180 ° arc (2.5 ") - connector (2.5") - 45 ° bend (2.5 ") - 500mm aluminum pipe (2.5") - 45 ° bend (2.5 ") - connectors (2 , 5 ") - 90 ° Break (2.5" to 3 ") - apexi filter
A different take on the cold air feed theme, only 1 question is there adequate water protection, from puddles etc?
2tongues A different take on the cold air feed theme, only 1 question is there adequate water protection, from puddles etc?
Thats a good move, as IS200 Engines look messy without the air box in place.
Seen this done before on the is200, works well from what i've read in the past, direct air flow to the filter and the rear section acts like a built in airbox, if you can find the newer inner plastic wing with the vents in, they help the air to escape causing less drag plus help to cool your brakes
looking good matey!!!
