Boot release not working :(
Ok guys suddenly my boot release has stopped working from the lever in the car, i can open the boot by key but the lever doesn't do anything.
Is the lever on a cable release? or any ideas?
Bandit Dan have you turned the lock round on the boot? if its in a certain position it wont work with the interior release? its part of the valet setup on the car itself?
agree with Bandit you'll have locked the boot
aaronabbott never knew that
Bandit Yes mate, if you turn the lock round to a certain position it wont open with a 2 button key (iirc) same as the glove box, you can lock it with the 3 button but the 2 button one wont unlock it or something like that? stops people going in your boot if its in for a service etc :thumbup:
ahh I shall have a look at this chris I have 2 3button keys so not tried with a 2 button, shall report back later
My cable slipped on the inside of the boot, causing the release to stop working (interior handle went floppy). It is worth removing the carpet cover and taking a look, its black and on the right had side as your looking at the back of the car. Solved with 2 tie wraps.
I used a claw hammer (the claw bit) to remove the plastic retainers of the carpet.
aaronabbott or keep people from getting out
2tongues My cable slipped on the inside of the boot, causing the release to stop working (interior handle went floppy). It is worth removing the carpet cover and taking a look, its black and on the right had side as your looking at the back of the car. Solved with 2 tie wraps.
