JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! Lexus is200 how to remove fit uprated anti roll bars
20-02-2017, 11:12 AM
well here goes very simple and a very quick job to do....:thumbup1::thumbup1:
tools req:
rachit,extension,12mm socket,14mm socket,12mm spanner and a pair of small mole grips.....
rear bar done first..
remove the 12mm nut and bolt and remove the anti roll bar link with the bar
[Image: p0404101318.jpg]
then remove these two 12mm bolts(2 either side)
[Image: p040410131801.jpg]
now you can just lower the old poop bar out..
now heres a tip some people say soon as the anti roll bar link starts spinning cut it off and buy a new one.....dont its doughnuts talking about stuff the dont know about...course it will spin its a ball in a joint!!
[Image: p0404101327.jpg]
if it spins their is a sholder(i'm holding a sump washer next too it)take your mole grips and clamp them on to the sholder
[Image: p040410132701.jpg]
now the nut can be removed(if it still spins you need to clamp tighter)
now rebuild..........
on to the front
remove the 14mm nuts(1 either side same as the rear if it spins get the molegrips out)
[Image: p0404101342.jpg]
then remove the 4 12mm bolts(2 either side)
[Image: p040410134201.jpg]
now drop the bar out note their is a a/c pipe that makes it a bit fiddly.
[Image: p0404101355.jpg]
now rebuild with your new front bar make sure you tighten everything take her out on the road and enjoy!!trust me you will!!!!
diff between the rear bars..
[Image: p0404101325.jpg]
diff between the fronts
[Image: p0404101352.jpg]
and on the car
[Image: p0404101339.jpg]
[Image: p0404101403.jpg]
hope this helps some peeps.......
took me 20mins but that was because i had to take photos....
Edited 03-04-2010, 08:53 PM by ormi.
20-02-2017, 11:12 AM #1
tools req:
on to the front
and on the car
20-02-2017, 11:17 AM
top work mate
20-02-2017, 11:17 AM #2
top work mate
20-02-2017, 11:22 AM
Good work Blue Hand Ormi :p
But it does help if you have got a ramp to use, which most of us dont :lol:
20-02-2017, 11:22 AM #3
21-02-2017, 12:41 AM
Top work mate
21-02-2017, 12:41 AM #4
Top work mate
21-02-2017, 12:53 AM
Nice one matey, let the fun begin :thumbup:
21-02-2017, 12:53 AM #5
abactus
21-02-2017, 09:25 AM
nice photostory
good job Smile
abactus
21-02-2017, 09:25 AM #6
nice photostory
good job Smile
21-02-2017, 09:28 AM
Reps left mate good walk through:thumbup1:
21-02-2017, 09:28 AM #7
22-02-2017, 12:23 AM
Wooow, there is a significant rust under your car, but good review
22-02-2017, 12:23 AM #8
22-02-2017, 12:33 AM
ormi you a smurf? Big Grin
Great guide mate
22-02-2017, 12:33 AM #9
Great guide mate
22-02-2017, 12:50 AM
dimis Wooow, there is a significant rust under your car, but good review
We have salt on our roads in the winter, I doubt you have that problem in Greece :laugh:
22-02-2017, 12:50 AM #10
Views 183
13-12-2022, 05:57 AM
Replies 46
Views 7,263
16-03-2022, 12:02 AM
Last Post by Emissary
Views 807
10-09-2021, 01:07 PM
Replies 25
Views 4,576
18-08-2019, 06:32 AM
Last Post by Johny47
Views 522
24-01-2019, 02:06 PM
Views 2,001
03-10-2018, 08:33 AM
Views 826
04-09-2018, 10:45 AM
Replies 24
Views 2,154
19-07-2018, 10:57 AM
Replies 41
Views 3,055
09-04-2018, 11:19 PM
Last Post by IanS200
