Discs & Pads
Discs & Pads
What do people recomend as a good combination,
im doing a full refurb of front and rear as the paint is flaking off and the fronts seem to be sticking its hard to move the drivers side wheel when jacked up so must be slightly stuck on and looks like its wearing down pretty quick lol
just ordered a recon kit for both front and rear :thumbup:
Well I ordered my pads from here...
http://www.dcperformance.co.uk/cheap/525...pp408.html
Was recommended them by Chris, these are for the front incase you are interested in changing them at the same time.
Also get yourself some dot 5.1 fluid
Moley Well I ordered my pads from here...
The Black Diamond disks and pads are fantastic, low dust and good bite from cold to hot, its what's on my........... Chri5's IS.
I have Black Diamond discs and pads now installed on my car.
If your discs are still good, then just pads will do mate.
But if you are changing your disc because they are past their best , then you would need to do pads at the same time, no point putting on new discs with old pads
