JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Changing rear discs
Changing rear discs
Changing rear discs
James S
11-03-2020, 10:10 AM
Help please!
I am really struggling to change my rear discs. I have done it in the past but just can't remember how!
I've jacked up both back wheels and let the hand brake off, but still can't get them off.
What am I doing wrong?
James S
11-03-2020, 10:10 AM #1
Help please!
iceman
11-03-2020, 11:17 AM
make shore the hand brakes off if so use a block of wood and a hammer to the back turning it every now and again or just use a rubber mallet if you have one .the shoes are most likely stuck open.hope that helps
PS if that does not work screw the wheel nuts back on just to cover the threads the hit it on the front between the threads.
Edited 22-04-2013, 09:02 PM by iceman.
iceman
11-03-2020, 11:17 AM #2
11-03-2020, 12:55 PM
You need to line up the inspection hole to a certain position on the hub, then poke a screwdriver through the hole and spin round the tension adjuster for the handbrake pads to back them away from the drum. Chances are they are just getting wedged on the lip they have worn inside the drum part of the disc.
11-03-2020, 12:55 PM #3
James S
11-03-2020, 10:25 PM
Cheers guys! Should I slacked the handbrake cable in the cabin too?
James S
11-03-2020, 10:25 PM #4
iceman
11-03-2020, 10:38 PM
I would leave the cable for now.
Edited 23-04-2013, 08:13 AM by iceman.
iceman
11-03-2020, 10:38 PM #5
James S
12-03-2020, 10:38 AM
Managed to sort this, thanks
James S
12-03-2020, 10:38 AM #6
Views 192
15-07-2020, 06:16 AM
Last Post by Mr-cth
Views 601
30-07-2019, 08:00 AM
Views 675
04-06-2019, 06:03 AM
Views 341
22-04-2019, 10:33 PM
Views 967
22-08-2018, 09:36 AM
Views 558
11-07-2018, 10:12 PM
Views 1,026
06-07-2018, 10:00 AM
Last Post by Stoney
Views 778
01-07-2018, 01:41 AM
Last Post by E55EX_RACER
Replies 24
Views 1,264
13-02-2018, 01:15 AM
Last Post by Phil01
Replies 23
Views 1,778
03-01-2018, 09:09 PM
Last Post by Bandit
