JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension rear rollbar woes, need some help
18-08-2018, 01:53 PM
Sheared a bolt, then sheared the screw extractor in the rear anti roll bar bushing clip bit. There is a nut on the other side that's connected to the sub frame, that appears to be welded on either side. Tried drilling again with the screw extractor in, but its ******* invincible.
Basically, is it actually meant to be welded there? I'm tempted to just bash it off, pull the bolt out and put a new nut on the end.
Anyone know the correct bolt measurements for the rear ARB fittings?
Front ones went on ok though! Big Grin
Edit: Everything back there is rusted right through, including the roll bar. Nightmare.
Edited 29-09-2011, 11:29 PM by el_bandido.
18-08-2018, 01:53 PM #1
18-08-2018, 02:01 PM
Lots of penetrating fluid in advance for next time!
I know a few of mine were proper rusted and I had to drill a few and bolt them. Does the bit come off the car so you can drill it out off the car?
18-08-2018, 02:01 PM #2
18-08-2018, 02:11 PM
like i said earlier mate had to cut mine out with a angle grinder even with a serious amount of Plusgas
Edited 29-09-2011, 11:46 PM by Dan_Turism0.
18-08-2018, 02:11 PM #3
18-08-2018, 09:39 PM
Stav - Drilling it out shouldn't be a problem. There is another 12mm sized nut behind the bolt that appears to be welded, I just thought it might be easier to cut that off and then hit the old bolt through, as it would no longer be threaded on to anything.
Drills ahoy! I don't fancy getting any naked flames that close to my petrol tank.
18-08-2018, 09:39 PM #4
18-08-2018, 09:48 PM
Cut mine off mate, came off quite easy too after hitting them with a hammer and chisel :blink::blink: 3 of mine broke off so used nuts and bolts with thread lock to stop them coming undone :thumbup1:
18-08-2018, 09:48 PM #5
18-08-2018, 09:54 PM
Cool, that was pretty much my plan from here on. Thanks for the info guys!
18-08-2018, 09:54 PM #6
18-08-2018, 09:58 PM
Mine came off very easy mate, think the nuts are only held on by 2 spot welds? and then used new nuts and bolts to refit the roll bar :thumbup1:
18-08-2018, 09:58 PM #7
18-08-2018, 10:03 PM
Awesome. Fortunately the ball joints are all fine, fittings for the drop links are a bit stiff but they undid without causing any problems. Just seems to be all the bolts around the bushings. I am seriously concerned about how badly rusted my factory rear rollbar is though, no wonder the car feels like a boat so much!
18-08-2018, 10:03 PM #8
18-08-2018, 10:25 PM
yeh i know mate, mine were the same (2000 model), painted a lot of mine underneath with black hammerite smooth, after giving most of it a good clean off :thumbup1:
18-08-2018, 10:25 PM #9
18-08-2018, 10:27 PM
I've got a lot of Hammerite and lacquer left over from my brake callipers. Might give it a once over.
18-08-2018, 10:27 PM #10
Views 178
15-07-2020, 06:16 AM
Last Post by Mr-cth
Views 291
12-03-2020, 10:38 AM
Last Post by James S
Views 521
30-07-2019, 08:00 AM
Views 589
04-06-2019, 06:03 AM
Views 309
22-04-2019, 10:33 PM
Views 507
11-07-2018, 10:12 PM
Views 932
06-07-2018, 10:00 AM
Last Post by Stoney
Replies 24
Views 1,116
13-02-2018, 01:15 AM
Last Post by Phil01
Views 1,069
10-08-2017, 11:47 AM
Last Post by iano21
Views 612
29-04-2017, 12:46 PM
Last Post by Timbo
