JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza well thought i would have an easy day......how wrong was i
04-05-2017, 11:47 AM
well got in to work and the boss handed me a set of keys to a 58plate corolla verso 2.2.....brought it in and checked it over time to strip the engine out it needs a head gasket.........
well their is a problem with the gaskets and the coolant its the wrong coating on the gasket the pink coolant removes this and well it starts to shift about..
removed the engine removed the inlet manifold,exhaust manifold and turbo then removed the head........car req an engine the gasket has been moving about so much it has caused indenting in the head and the block!!!!
[Image: p1406101732.jpg]
[Image: p1406101739.jpg]
[Image: p140610173901.jpg]
[Image: p140610173902.jpg]
[Image: p1406101740.jpg]
let the nightmare begin..
Edited 15-06-2010, 09:27 PM by ormi.
04-05-2017, 11:47 AM #1
Chri5
04-05-2017, 11:52 AM
Is this a common fault with them mate???
Chri5
04-05-2017, 11:52 AM #2
russelllinn
:ohmy: looks like fun that should keep you busy!! I say its been coming though been far too busy on your own car :wink: :laugh:
[Image: AliceTrack-1.jpg]
Have a look at my Scooby project thread here
My garage
Subaru
russelllinn
04-05-2017, 11:52 AM #3
My garage
Subaru
04-05-2017, 11:55 AM
Chri5 Is this a common fault with them mate???
yes mate all 2.2's could suffer with this.....
na not too long mate took me 3 hours to get it that far
04-05-2017, 11:55 AM #4
04-05-2017, 11:58 AM
Not like you mate to work on customers cars is it LOL
So when will this job be finished and is it warranty work
04-05-2017, 11:58 AM #5
04-05-2017, 01:01 PM
prob get the short block and a bare head on thurs and will be finished approx thurs at 3... swapping over and lapping all the valves takes the longest......
the 2.2's suffer from burning oil aswell which involves a strip and rebuild...........
the warranty on the engine has been extended too 100,000 miles............
a lot of the 2.2,s might suffer......
auris,avensis,rav4....
its a 24 hour job...........
04-05-2017, 01:01 PM #6
04-05-2017, 01:03 PM
Moley Not like you mate to work on customers cars is it LOL
:laugh::laugh::laugh::laugh:.....at least your day will fly being so busy
04-05-2017, 01:03 PM #7
05-05-2017, 09:44 AM
well i got the bare head today so had to strip the old one and clean up the valves and lap them in......
the new head....
[Image: 18798506.jpg]
and the top of the new head...
[Image: 71315049.jpg]
a carboned up valve before a clean.
[Image: 85887437.jpg]
nice clean valve..
[Image: 93297127.jpg]
a clean valve and carboned up valve..
[Image: 48218711.jpg]
valve stem oil seals all fitted..
[Image: 71005952.jpg]
left valve has been lapped right valve not....
[Image: 16451480.jpg]
05-05-2017, 09:44 AM #8
the new head....
nice clean valve..
05-05-2017, 09:52 AM
these fit under the valve spring if you dont the spring will wear through the head!!!
[Image: 72630493.jpg]
valve spring,spring top and collet
[Image: 60522081.jpg]
inlet valves all in place..
[Image: 77071404.jpg]
the side of the head is very sharp..
[Image: 83926344.jpg]
all inlet valves,springs,tops and collets all in place
[Image: 32984783.jpg]
old head,check out the carbon build up..
[Image: p1606101138.jpg]
Edited 16-06-2010, 07:28 PM by ormi.
05-05-2017, 09:52 AM #9
05-05-2017, 09:53 AM
loving the bling Ormi... :lol:
05-05-2017, 09:53 AM #10
Views 779
10-07-2018, 02:37 PM
Views 1,064
24-08-2017, 06:34 AM
Replies 22
Views 1,134
18-01-2017, 06:06 AM
Last Post by Mikey
Views 784
06-09-2016, 02:36 PM
Last Post by ormi
Replies 25
Views 994
09-08-2016, 10:13 PM
Last Post by Bobby
