JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Replacing N/side suspension arm-how easy is it?
rosey1955
13-06-2018, 04:44 AM
My IS200 recently passed its MOT' with a couple of advisories:
I was advised that the bush had a fair amount of play, and would require replacement. Lexus do not sell the bush alone and as such I have had to purchase the suspension arm.
How easy is it to change the arm? Has anyone completed this task?
rosey1955
13-06-2018, 04:44 AM #1
13-06-2018, 04:48 AM
I have taken them off before but never replaced. It won't be that hard, you will need some big sockets, 14,17,19mm 1/2" drive, a breaker bar and some WD40/Plusgas. Soak the nuts and bolts overnight before attempting removal if you can. You'll want a wheel alignment afterwards too.
13-06-2018, 04:48 AM #2
rosey1955
13-06-2018, 05:06 AM
No, its the front one:
http://www.camskill.co.uk/m30b0s2940p409..._ADT38697_
I was wondering if I could fit them without a pit or ramp, etc. In other words sitting on the floor of my garage with thew car jacked up?
rosey1955
13-06-2018, 05:06 AM #3
13-06-2018, 05:19 AM
Oh yeah no problem. You might need to get clever and use a jack to jack up the suspension strut while the car's up in the air but it's all doable - you have loads of room once you've got the wheel and brake disc off.
You'll need a balljoint splitter too - you can unbolt the balljoint from the bottom of the hub but you'll still need to remove it from the arm to transfer it. You can probably get away with a forked one from Halfords, they aren't expensive.
Edited 25-07-2011, 02:54 PM by toxo.
13-06-2018, 05:19 AM #4
13-06-2018, 05:30 AM
rosey1955 I was wondering if I could fit them without a pit or ramp, etc. In other words sitting on the floor of my garage with thew car jacked up?
You'd be surprised what you can can achieve without ramps or a pit.
Though it should go without saying that Axle Stands are essential EVERY time you jack your car off the floor. Smile
13-06-2018, 05:30 AM #5
suspension noises
by lexynik
Replies 23
Views 1,630
09-12-2021, 10:38 PM
Last Post by jeorje_2000
Views 242
11-07-2020, 01:53 AM
Last Post by lex2oos
Views 916
06-10-2018, 03:28 AM
Views 490
17-09-2018, 11:12 AM
Last Post by ormi
Views 358
20-07-2018, 01:40 AM
Last Post by Fozzy
Views 989
10-07-2018, 02:37 PM
Views 1,462
06-07-2018, 06:07 AM
Last Post by Stoney
Views 975
16-05-2018, 04:33 AM
Views 325
16-03-2018, 11:10 PM
