JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza water in drivers side bolster, water coming in through pillar
30-09-2019, 04:31 AM
My mates IS200 sport cross is having water leakage problems, anyone know what the solution is?
30-09-2019, 04:31 AM #1
30-09-2019, 04:39 AM
Yea - remove his rear window wiper motor and send it to me.
30-09-2019, 04:39 AM #2
30-09-2019, 04:44 AM
Which pillar is it coming through?
Could it be a blocked drainage channel from the sunroof?
30-09-2019, 04:44 AM #3
30-09-2019, 04:50 AM
I told him to check the sunroof, but I thought the pipe was passenger side, or are there two? I'm pretty sure it's coming in drivers side.
30-09-2019, 04:50 AM #4
FirebirdPhil Yea - remove his rear window wiper motor and send it to me.
yeee no :p
30-09-2019, 04:50 AM #5
yeee no :p
30-09-2019, 04:54 AM
:thumbdown:
30-09-2019, 04:54 AM #6
:thumbdown:
30-09-2019, 05:48 AM
el_bandido I told him to check the sunroof, but I thought the pipe was passenger side, or are there two? I'm pretty sure it's coming in drivers side.
I don't actually know, but I'd expect there to be two personally, one in each of the front corners. I'm sure someone else will pop along and confirm if that's the case.
30-09-2019, 05:48 AM #7
30-09-2019, 06:02 AM
I think there is 2 best thing is remove the pillar cover and sit in the car while Some one else pours a pint of water over the roof see if you can track down where it starts etc
Get them signed up over here mate Smile
30-09-2019, 06:02 AM #8
Mr Reman
Most cars with a factory tilt and slide sunroof have 4 drain tubes (One at each corner of the sunroof "Pan"). This is so it doesn't matter if the cars parked facing up hill, Down hill or side on to the slope, Water can still drain from whichever corner it accumulates in.
Scotty B.
Air filter by K+N, Exhaust by Japspeed, Brakes by Mintex......... And a scuffed rear arch by my sister. Huh
Mr Reman
30-09-2019, 06:02 AM #9
Scotty B.
01-10-2019, 02:55 AM
Mr Reman Most cars with a factory tilt and slide sunroof have 4 drain tubes (One at each corner of the sunroof "Pan"). This is so it doesn't matter if the cars parked facing up hill, Down hill or side on to the slope, Water can still drain from whichever corner it accumulates in.
Scotty B.
Correct the IS has 4 drain holes, all can be cleaned out using a length of strimmer wire. I've just done mine!!
01-10-2019, 02:55 AM #10
Scotty B.
Views 242
11-07-2020, 01:53 AM
Last Post by lex2oos
Views 374
19-09-2019, 08:41 AM
Last Post by jomo
Views 398
20-03-2019, 09:50 AM
Views 490
17-09-2018, 11:12 AM
Last Post by ormi
Views 345
31-08-2018, 11:41 AM
Last Post by Fozzy
Views 358
20-07-2018, 01:40 AM
Last Post by Fozzy
Views 1,462
06-07-2018, 06:07 AM
Last Post by Stoney
Views 975
16-05-2018, 04:33 AM
Views 325
16-03-2018, 11:10 PM
