JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza thought i'd have an easy day at work!!how wrong i was!!
22-10-2016, 01:35 PM
went in to work (yes mole sometimes i do work:laughSmile went for the next job on the rack an oil leak on a 2.2 rav 4 07 plate!!traced the oil leak to the oil feed union for the turbo!!!!and the timing chain cover(toyota no longer use belts) well heres a few pics on what you have to remove to repair the leaks Confusedhock:!! if it was out of warranty you'd be looking around £1700 worth of labour!!Confusedhock: approx 17 hours to repair.
[Image: p0312091315.jpg]
my tool box in the back ground.
[Image: p0312091323.jpg]
the timing case which was at fault.
[Image: p0312091457.jpg]
timing casing removed for the clean up and reseal.
[Image: p0312091541.jpg]
all done will be putting the engine back in tomorrow.:thumbup:
22-10-2016, 01:35 PM #1
22-10-2016, 01:40 PM
£100 an hour!
22-10-2016, 01:40 PM #2
£100 an hour!
22-10-2016, 02:02 PM
yip mate think its 104 inc vat!!Confusedhock:
22-10-2016, 02:02 PM #3
23-10-2016, 02:59 AM
That is a big job, and a higher hourly rate than I would have expected - what's the Lexus rate then? (Need to check my old invoices, I can't remember it being so high!)
23-10-2016, 02:59 AM #4
23-10-2016, 04:18 AM
ormi yip mate think its 104 inc vat!!Confusedhock:
Cant believe you are working for a change mate :Chair::Chair:
But £104 an hour you must be good :Bazza:
23-10-2016, 04:18 AM #5
23-10-2016, 04:22 AM
Didn't the Saab 9-5 Areo have to have the engine out to do the timing cover also?
A hell of a lot of work though for a small repair.
23-10-2016, 04:22 AM #6
23-10-2016, 09:44 AM
back in and running sweet as a nut and the best bit oil leak gone!!woop woop
if you have an older car say 4 years or older the hourly rate is £78 inc vat
ps the 2.2 avensis is the same!!
23-10-2016, 09:44 AM #7
mattlaw
26-10-2016, 11:05 AM
pretty much the same as whats in the 220d, are you doin alot of piston rings on them? were doin roughly 2 or 3 complete strip downs a week
mattlaw
26-10-2016, 11:05 AM #8
Views 475
21-04-2019, 11:13 AM
Views 992
10-07-2018, 02:37 PM
Views 1,318
24-08-2017, 06:34 AM
Views 895
24-06-2017, 08:05 AM
Last Post by Dark Samurai
Views 1,258
12-06-2017, 06:13 AM
Views 1,136
06-05-2017, 02:26 PM
Last Post by ormi
