JapCarForum General Discussions New Members is200 cd player replacement
ged
25-07-2018, 02:45 PM
hi everyone
just bought a used is200 and as usual cdplayer is err code 3 ,took it to bits and cleaned laser etc but no change .
my question is can i put in an aftermarket radio without using a bypass lead and still use existing amp ?
any help would be appreciated.
ged
25-07-2018, 02:45 PM #1
hi everyone
widnes_is200
25-07-2018, 04:41 PM
hi ged and welcome too the club. i have no exact answer for u other than when i bought my is it had a after market stereo and was wired too the origional loom, i changed this for a bypass cable
widnes_is200
25-07-2018, 04:41 PM #2
garyskisplym
25-07-2018, 06:34 PM
welocme to the site.
Im sure someone soon will be along to answer this question, but same what i am thinking
garyskisplym
25-07-2018, 06:34 PM #3
26-07-2018, 03:32 AM
Ged welcome to the club.
So to get the right answer to your question.
What model IS do you have and what age is your car.
26-07-2018, 03:32 AM #4
kevinsgs300
26-07-2018, 05:52 PM
welcome to the club mate
kevinsgs300
26-07-2018, 05:52 PM #5
26-07-2018, 06:04 PM
you might find like me that you have no amp and you just buy a mr2 harness.... and welcome to the club. :thumbup1:
26-07-2018, 06:04 PM #6
ged
10-08-2018, 11:32 AM
thanks for all the replies
i have a 2000 is200 se thought i might rewire original loom going into cd player assuming it i can find wiring diagram of the connector and still use original amp otherwise bypass lead it is.
ged
10-08-2018, 11:32 AM #7
Y2KANJAR
10-08-2018, 02:40 PM
or you can buy another lexus head unit Smile
[SIGPIC]SINGH[/SIGPIC]
Y2KANJAR
10-08-2018, 02:40 PM #8
ged
13-08-2018, 04:58 AM
bought the bypass lead fitted it to the car and didnt work
the lead had 2 yellow cables joined together and both the red and the yellow power cables had to plug into it for it to work but wouldnt keep its memory.
Any ideas would be appreciated.
ged
13-08-2018, 04:58 AM #9
13-08-2018, 09:13 AM
you need to swap the red and yellow leads over as the 12v ignition line is in the wrong place on the leads hence the 2 connectors just put
red - yellow
yellow - red
this should fix it mate
13-08-2018, 09:13 AM #10
red - yellow
yellow - red
Views 1,957
03-08-2024, 12:52 PM
Views 1,330
03-12-2022, 04:34 PM
Last Post by kevinsgs300
Replies 188
Views 16,662
28-07-2022, 05:34 PM
Views 1,808
22-07-2022, 05:37 AM
Views 1,138
17-05-2022, 02:46 AM
Last Post by 350zLad
Views 2,493
15-05-2022, 09:12 AM
Last Post by tim996
Views 1,394
27-12-2021, 08:06 PM
Last Post by Jimbob-T-Lex
Views 1,328
13-12-2021, 07:01 AM
