JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza auto close window unit
17-10-2017, 11:13 AM
well i'm about to fit one of these systems to my is200 and wanted to know about fitting them. is it better to run the wires to each window or just fit them to loom at the fuse panel. and one done one of these who can offer any advice
17-10-2017, 11:13 AM #1
17-10-2017, 11:43 AM
Depends how you need to wire it mate to be honest,
17-10-2017, 11:43 AM #2
17-10-2017, 11:45 AM
what unit are you intending on fitting ?
17-10-2017, 11:45 AM #3
17-10-2017, 12:15 PM
i got a china unit i guess. but what i need to know is are they a + or - system.
all i got was this
[Image: window.jpg]
17-10-2017, 12:15 PM #4
all i got was this
[Image: window.jpg]
17-10-2017, 12:21 PM
the positive and negative wont mater i think as this replaces the link on the up side of the window circuit
what will you be using to trigger the closure from the alarm ?
17-10-2017, 12:21 PM #5
17-10-2017, 12:22 PM
You need to run wires to all the doors mate, the lexus uses a multiplex from the drivers switch.
And the fuses dont go straight to the motors you'll have to run wires to all doors.
17-10-2017, 12:22 PM #6
17-10-2017, 12:23 PM
And its positive you need mate, as you need so send a positive signal as its always connected to the ground signal.
17-10-2017, 12:23 PM #7
17-10-2017, 12:24 PM
ahh yes sorry i was thinking from when i installed my original system
17-10-2017, 12:24 PM #8
17-10-2017, 01:11 PM
trigger will be the same as my folding mirrors i guess. or can i take it from the door lock ?
17-10-2017, 01:11 PM #9
17-10-2017, 01:20 PM
you will need to take it from the relay output of the folding mirrors the standard alarm output is not of high enough current
17-10-2017, 01:20 PM #10
Views 315
12-06-2021, 09:38 AM
Views 144
15-07-2020, 06:55 AM
Last Post by Dub///15
Views 230
22-11-2019, 02:45 PM
Views 476
27-06-2019, 09:37 PM
Views 609
18-06-2019, 11:35 AM
Last Post by Matt_C
Views 286
09-05-2019, 12:39 PM
Last Post by jasons
Views 387
16-12-2018, 11:11 AM
Last Post by Barry
Views 776
16-04-2018, 04:32 AM
Views 702
14-11-2017, 04:43 AM
Last Post by Bandit
