JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Wings. IS300 same or different to IS200?
03-12-2017, 12:10 PM
Can anyone tell me for sure if the front wings on the IS300 are the same or different to the IS200?
I've read a couple of threads dotted around the interwebz suggesting that the reason you cant fit Is300 headlights on an IS200 is because of a difference to the wing?
I'm just wondering that if I buy an IS200 passenger side wing from a scrappie and try to bolt it on my IS300 if I'll have problems?
03-12-2017, 12:10 PM #1
03-12-2017, 12:16 PM
I believe the IS300 wing is a bit wider than the 200 mate.
03-12-2017, 12:16 PM #2
03-12-2017, 12:17 PM
Dark Samurai I believe the IS300 wing is a bit wider than the 200 mate.
Bums if that's the case.
03-12-2017, 12:17 PM #3
spikes
03-12-2017, 12:24 PM
i thought it was because the 300 has hid headlights which are different fitting so wings are a bit different in that area
spikes
spikes
03-12-2017, 12:24 PM #4
spikes
Well, that's what me and my dad have noticed between two members cars behind us in a convoy. One was a Late IS200 (MarsdenDean) and one was an '02 IS300 (is300_dino) and the one's on the IS300 did look slightly wider.
And, the IS300 indicators are in the top of the headlight, whereas the IS200 are in the center.
03-12-2017, 12:24 PM #5
03-12-2017, 12:29 PM
they are no wider as both cars still are the same size according to specs i know the lights differ though but i thought that was to do with the mounting frames??..
phone up lex and ask for the part number for the wings??
03-12-2017, 12:29 PM #6
03-12-2017, 12:32 PM
ormi they are no wider as both cars still are the same size according to specs i know the lights differ though but i thought that was to do with the mounting frames??..
Yeah possibly the only way to find out I guess. I'll be mildly gutted if they are different.
£50 for a wing from breakers in black 202.
£470 for a wing + spraying from garage Confused
03-12-2017, 12:32 PM #7
03-12-2017, 12:47 PM
tbh i think its just a small adjustment you would need to do(read somewhere its just a tab that gets cut off)but im sure thats on the inner wing...
right just googled it...........
wings are the same so you'll be cool mate!!
theirs only a problem if your trying to fit 300 lights in a 200 and its the inner wing you have to mod......
hope that helped..
03-12-2017, 12:47 PM #8
hope that helped..
03-12-2017, 12:49 PM
ormi tbh i think its just a small adjustment you would need to do(read somewhere its just a tab that gets cut off)but im sure thats on the inner wing...
hope that helped..
mwah xxxx
Seriously appreciated mate Confusedmoke: Breakers shopping tomorrow it is Big Grin
03-12-2017, 12:49 PM #9
hope that helped..
mwah xxxx
03-12-2017, 01:22 PM
well i fitted is300 lights without problems. but i did have hids as standard in my oem ones. so i guess there might be some difference but i cant see any and the fitting is the same ( screw wise) so for me there was no worries
03-12-2017, 01:22 PM #10
Views 411
13-12-2023, 02:06 PM
Views 542
09-11-2023, 03:46 AM
Last Post by Dinho
Views 905
06-11-2022, 01:49 AM
Views 3,042
02-11-2022, 10:55 AM
Views 370
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,592
23-02-2022, 01:20 PM
Views 411
18-10-2021, 02:04 AM
Views 576
03-09-2021, 11:04 AM
Views 532
29-08-2021, 09:59 AM
Replies 35
Views 8,064
04-08-2021, 04:34 AM
Last Post by cjoseph
