JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Fitting IS300 exhaust on an IS200
Pages (4): 1 2 3 4 Next
08-12-2017, 01:44 PM
Morning all well as title says really lol
I have an is300 exhaust and want to fit to an is200 now it looks identical in length etc so that won't be a problem
However
The is300 has the sensor located precat I believe where as the is200 is located post cat so my sensor won't reach
Do I need to remove and rework wiring can I get a sensor bypass or anything
Think this is a poor design lol
Cheers
Rabs
08-12-2017, 01:44 PM #1
However
Cheers
Rabs
08-12-2017, 01:51 PM
Oh mate, I believe the 300 has an extra O2 sensor. So that may be the extra hole.
08-12-2017, 01:51 PM #2
08-12-2017, 03:06 PM
Think this has been brought up by someone they had to get a hole drilled and a threaded nut welded on so the sensor could be fitted.
08-12-2017, 03:06 PM #3
08-12-2017, 11:50 PM
Dark Samurai Oh mate, I believe the 300 has an extra O2 sensor. So that may be the extra hole.
no not an extra hole infact no hole after the cat wrong place to work on a 200 so guess ur gonna have the same issue when you buy demons as the hole will be in the wrong place for that one....
Edited 20-01-2011, 09:36 AM by Rabster.
08-12-2017, 11:50 PM #4
09-12-2017, 12:53 AM
Ah should be ok, just get it drilled and a thread welded there. Our Bank 2 Sensor 2 heater element doesn't work anyway lol, so will show up a fault code if it's in there or not.
09-12-2017, 12:53 AM #5
09-12-2017, 01:06 AM
Oli i could be wrong but thats not the sensors i am talking about
bank 2 sensor 2 would be located on the Manifold in the engine bay surely not under the car, unless the 300 only has those 2 sensors and not one under the car?
you will still have the problem that the hole will be in the wrong place on your new exhaust so you will have to get one hole welded shut and one hole drilled.
my question still stands though can i get a Simulator to plug on to save drilling the hole ?
09-12-2017, 01:06 AM #6
09-12-2017, 01:22 AM
[Image: is-300-o2-sensor-location.jpg]
That's B2 S2. Looks under the car.
09-12-2017, 01:22 AM #7
09-12-2017, 01:48 AM
im afraid OLI you could be wrong
all work shop diagrams show that the under car sensor on both the IS200 and the IS300 that sensor is Bank 1 sensor 2
Edited 20-01-2011, 11:30 AM by Rabster.
09-12-2017, 01:48 AM #8
they also clearly show the location difference
09-12-2017, 01:48 AM #9
09-12-2017, 01:49 AM
i got that from the internet, so they're wrong.
09-12-2017, 01:49 AM #10
Views 411
13-12-2023, 02:06 PM
Views 542
09-11-2023, 03:46 AM
Last Post by Dinho
Views 905
06-11-2022, 01:49 AM
Views 3,042
02-11-2022, 10:55 AM
Views 370
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,592
23-02-2022, 01:20 PM
Views 411
18-10-2021, 02:04 AM
Views 576
03-09-2021, 11:04 AM
Views 532
29-08-2021, 09:59 AM
Replies 35
Views 8,064
04-08-2021, 04:34 AM
Last Post by cjoseph
