JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Fuel Tank Empty full Sensor
16-12-2017, 12:03 PM
Anyone changed there's to a different one.
Been doing some reading seems that there are 2 feeds that go 2 the Cluster does this mean 2 Sensors?
Has anyone changed it to one sensor?
16-12-2017, 12:03 PM #1
16-12-2017, 01:11 PM
Yes theres 2 sensors as the tank has two sides over a raise.
But the cluster takes its readings from the amount of times the injectors are fired, only checking the sensors every quarter of a tank. Thats why tuners had issues with the Gauge when fitting standalone ECU's (one my mapper solved somehow)
16-12-2017, 01:11 PM #2
16-12-2017, 01:36 PM
So are both sensors running in parallel then well ish lol
16-12-2017, 01:36 PM #3
17-12-2017, 03:28 AM
yeah
17-12-2017, 03:28 AM #4
yeah
17-12-2017, 04:14 AM
Hmm this could work then
17-12-2017, 04:14 AM #5
Phil01
17-12-2017, 01:15 PM
Where is the second sensor fitted, as I know one is in the tank unit/fuel pump.
Phil01
17-12-2017, 01:15 PM #6
17-12-2017, 01:23 PM
The other side of the tank
17-12-2017, 01:23 PM #7
Phil01
17-12-2017, 01:26 PM
how do you access it stav, as i have only seen one plate on top of tank, and only one loom.
Phil01
17-12-2017, 01:26 PM #8
18-12-2017, 12:24 AM
I assume its under the rear bench on the driver side:
http://bahamutcars.free.fr/workshop/IS_9...i_0030.pdf
18-12-2017, 12:24 AM #9
Views 304
29-11-2022, 03:38 AM
Last Post by phaebo
Views 278
28-01-2021, 10:29 AM
Views 318
14-02-2020, 10:45 AM
Last Post by argyle dan
Views 392
02-08-2019, 07:38 AM
Last Post by farnsworth67
Replies 32
Views 2,187
08-03-2019, 12:20 AM
Last Post by S
Views 614
18-01-2018, 06:44 PM
Last Post by liquidlazer
Views 400
21-08-2017, 09:02 AM
Last Post by Bandit
Replies 25
Views 1,573
06-07-2017, 05:04 AM
Last Post by LEX11S
