JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications supercharged IS200 hesitating at full throttle
Pages (4): 1 2 3 4 Next
S
09-01-2019, 02:03 AM
Morning all,
First 'hard' drive of the car last night since I supercharged it and at "full speed" and full throttle the car seems to hesitate, its as though the rev limiter is kicking in early (at just under 6k)
Is this a symptom of the HKS FCD I'm using or is something else causing this problem?
Any opinions on cause or solution would be greatly appreciated!
Thanks
David.
S
09-01-2019, 02:03 AM #1
Morning all,
Thanks
David.
09-01-2019, 02:12 AM
What setting is the FCD on ? It could be a symptom of it does the charger sound like its stressed when it hesitates ?
09-01-2019, 02:12 AM #2
S
09-01-2019, 02:17 AM
Not that I noticed but I couldn't really hear the charger over the sound of the exhaust and the wind!
I'll check the FCD when I finish work tonight.
S
09-01-2019, 02:17 AM #3
P.Lindblom
09-01-2019, 02:19 AM
It sounds like you might be hitting the fuel cut. A lower FCD setting might work, but it's not an ideal solution as you'll be running leaner instead.
P.Lindblom
09-01-2019, 02:19 AM #4
S
09-01-2019, 02:21 AM
I think one of your black boxes has moved to the top of priority list Mr. Lindblom!
S
09-01-2019, 02:21 AM #5
P.Lindblom
09-01-2019, 02:27 AM
Stix44 I think one of your black boxes has moved to the top of priority list Mr. Lindblom!
If it's AFR related my black box would probably do the trick. I've got one ready that I can send today mate.
P.Lindblom
09-01-2019, 02:27 AM #6
S
09-01-2019, 02:32 AM
I'll check the bank at lunch and see if I can get the money over to you.
S
09-01-2019, 02:32 AM #7
09-01-2019, 03:28 AM
Sounds like FCD to me
09-01-2019, 03:28 AM #8
eogbaker
09-01-2019, 03:39 AM
right just to clear up it is more like a quick misfire or splutter that happens on this car. Also it does seem a little bit down on power from when we first fitted it. Not sure if that is because of the ECU being a learning ECU and has changed things or if it is because the car now has the air box fitted.
eogbaker
09-01-2019, 03:39 AM #9
09-01-2019, 05:59 AM
Did you reset the ecu when you fitted the air box?
Also I imagine the air box is more restrictive than the induction kit as well.
09-01-2019, 05:59 AM #10
Views 1,764
05-07-2023, 05:08 AM
Last Post by damtrx
Views 824
17-04-2023, 03:51 AM
Views 1,418
05-04-2023, 03:19 AM
Last Post by damtrx
Views 734
01-03-2023, 01:51 PM
Last Post by TheDieselDoctor
Views 299
29-11-2022, 03:38 AM
Last Post by phaebo
Views 399
30-04-2022, 06:27 AM
Views 591
27-04-2022, 12:45 PM
Last Post by oedipus
Views 679
19-06-2021, 12:50 PM
