IS200 and IS300 o2 sensor locations and purposes...
I might show my n00bness here...so please feel free to whip out your flame throwers
On the IS200 the final o2 sensor is at the beginning of the mid-pipe, after the cat which is located in the downpipe, right? Therefore, I'm assuming that this means the purpose of that o2 sensor is to determine if the cat is working and whether emission levels are ok?
However, on the IS300 the final o2 sensor is in the down-pipe, just after the Y join and BEFORE the final cat. Therefore, there is no sensor to determine whether the final cat is functional. So, does this mean that this sensor is used for another purpose (maybe to trim fuel settings to avoid rich/lean)?
Or am I missing something?
Phil01 the final o2 sensor is S2 and is located in the front pipe approx under drivers seat, heated and controls fuel trim
