JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza How to fit rear mud flaps???
karlp
12-02-2018, 04:26 AM
Just bought some from moley but can't seem to the hang of fitting them?? Any pointers??
karlp
12-02-2018, 04:26 AM #1
12-02-2018, 08:42 AM
There are black plastic bits on the end of your bumper that are held on with three screws.
Remove the screws and plastic bit and fit the mud flaps. But cant remember if this is just for the front ?? But there will be screws like Dean has said on the rear bumper.
12-02-2018, 08:42 AM #2
karlp
12-02-2018, 10:45 AM
Any pics guys?? I had the rear wheel off and saw the 2 screws that screw into the bumper and then 3 larger nuts/screws further in the wheel arch, but the screw holes on mud flaps don't measure up to the holes in the arch??
karlp
12-02-2018, 10:45 AM #3
12-02-2018, 11:32 AM
Couuld be wrong, but I thought the fronts bolted straight on whereas the rears needed holes drilling?
12-02-2018, 11:32 AM #4
karlp
16-02-2018, 03:44 AM
any more help guys???
karlp
16-02-2018, 03:44 AM #5
Phil01
19-02-2018, 05:54 AM
Not fitted any to mine, but this was copied from another site,,,
to fit the rear ones properly you have to drill 1 hole into the edge of the plastic bumper, this is to allow fitment of another spring clip nut for a mudguard mounting screw. on the front you remove a little piece of trim about 4 screws i think then just screw the mudguard using existing holes.
0
Phil01
19-02-2018, 05:54 AM #6
0
karlp
19-02-2018, 05:58 AM
I've measured them up and it looks like you have to drill a hole into the rear bumper just under where the other bumper trim screw is, theres another hole on the under bit of the bumper as well? not sure I feel confident drilling into the bumper as theres not a lot of room for mistakes Sad
karlp
19-02-2018, 05:58 AM #7
Views 232
01-07-2021, 06:55 AM
Views 358
25-06-2021, 09:59 AM
Views 196
27-11-2020, 12:12 PM
Views 159
07-10-2020, 01:46 AM
Last Post by Stoney
Views 483
17-08-2020, 01:08 AM
Views 633
08-01-2020, 10:54 AM
Views 359
29-07-2019, 09:39 AM
Views 638
09-07-2019, 01:02 AM
Last Post by gc8_g_r
Views 400
18-06-2019, 03:14 AM
Last Post by Kevpr
