JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security IGN/+12v from passenger fuse panel.
14-04-2018, 02:01 AM
Does anyone have any tips on where I coupld pick up a healthy feed of constant +12v / Ignition and ground from the passenger fuse box?
I need to be able to pull around 5A and will be adding an inline fuse.
14-04-2018, 02:01 AM #1
14-04-2018, 02:44 AM
i would take it direct from the ignition circuit mate at the barrel very easy plus you can add a fuse box there as there is loads of room
14-04-2018, 02:44 AM #2
14-04-2018, 04:18 AM
Okey dude. I've already got a fuse tapped in over there so I'll just have to run the cables round the car a bit
14-04-2018, 04:18 AM #3
14-04-2018, 04:50 AM
you can get a cable up and over the dash by going behind the sat nav screen, failing that there is a small hole from passenger to driver on the top of the transmission tunnel
14-04-2018, 04:50 AM #4
14-04-2018, 04:51 AM
from past experience its best to take all your feeds from a central location that way if you ever need to isolate all after market items its easy to do so.....
14-04-2018, 04:51 AM #5
Are you available for hire? :p
Was thinking about buying one of these and running it directly from the ignition barrel wires:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...AQ:GB:1123
14-04-2018, 04:51 AM #6
14-04-2018, 04:52 AM
i am indeed mate im regularly rented out :confused:
14-04-2018, 04:52 AM #7
14-04-2018, 05:57 AM
Rabster i am indeed mate im regularly rented out :confused:
Hmm so the rumours are indeed true.
14-04-2018, 05:57 AM #8
14-04-2018, 07:06 AM
2tongues Hmm so the rumours are indeed true.
You should know mate afterthe Swiss trip Big GriniscoStu: lol
14-04-2018, 07:06 AM #9
14-04-2018, 07:33 AM
yea I still have those nightmare.
14-04-2018, 07:33 AM #10
Views 764
31-05-2018, 04:20 AM
Last Post by bounty`
Views 702
13-04-2018, 12:26 PM
Views 644
29-07-2017, 04:15 AM
Last Post by Duv
Views 439
19-11-2016, 03:22 PM
Last Post by Bandit
Views 420
19-11-2016, 03:20 PM
Last Post by Bandit
Views 918
19-11-2016, 03:16 PM
Last Post by Bandit
