JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Grille connections
Grille connections
Grille connections
Ally
10-05-2018, 04:55 AM
Hi folks, you know the 4 plastic connectors which attach the grille to the front bumper. Does anyone know the proper name for them? Out of the 4 connectors, i am down to 1 and a half :ohmy: Tried doing a web search for plastic screws / connectors but haven't found any yet
thanks
Ally
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
10-05-2018, 04:55 AM #1
thanks
Ally
10-05-2018, 05:01 AM
I think they are usually just referred to as "tabs".
10-05-2018, 05:01 AM #2
10-05-2018, 05:29 AM
Lexus will sell you a bunch for a couple quid...
DaveEdin Shahz - was cleaning out some paperwork today and found the invoice I have from Lexus with the bumper grill clips on it - the part number is 5211753010 in case you still need that...
10-05-2018, 05:29 AM #3
dodgydave
10-05-2018, 11:04 AM
You can get them on good old eBay too http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...004wt_1139 :biggrin:
These are slightly diferent to the ones for the grill but I think they will do.
dodgydave
10-05-2018, 11:04 AM #4
Ally
10-05-2018, 11:22 PM
dodgydave You can get them on good old eBay too http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...004wt_1139 :biggrin:
Excellent. Thanks Dave. If only i had thought to search for Toyota Retaining Bumper Trim Splash Rivet Clips Smile
Ally
10-05-2018, 11:22 PM #5
dodgydave
11-05-2018, 03:04 AM
Yer I know, I only have that link because someone on here found them some time ago and I now keep them in my watched list just in case :wink:
dodgydave
11-05-2018, 03:04 AM #6
11-05-2018, 03:27 AM
Careful with those ebay ones. Make sure you check the size of the old ones first. I bought some from that seller but I ordered the wrong size Sad
11-05-2018, 03:27 AM #7
Ally
11-05-2018, 03:31 AM
Will do. Thanks Jim Smile
Edited 22-06-2011, 01:05 PM by Ally.
Ally
11-05-2018, 03:31 AM #8
11-05-2018, 04:36 AM
If you do happen to measure them, can you post the sizes (pwetty plz). I need to get some too, but after ordering the wrong ones I spat the dummy and used zip ties :p
11-05-2018, 04:36 AM #9
11-05-2018, 04:37 AM
you could always put rubber nuts in and some stainless steel bolts.....
11-05-2018, 04:37 AM #10
Views 275
18-12-2021, 09:53 AM
Last Post by Matt_C
Views 561
25-02-2020, 03:56 AM
Views 533
05-08-2019, 08:34 AM
Last Post by PETEHAMASAKI
Views 887
09-09-2016, 04:20 AM
