JapCarForum Cars, Cars, Cars! General Car Maintenance Will these sparks work on the IS300...
19-06-2018, 09:03 AM
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...0412210150
I'm looking for some copper plugs with three ground prongs and a .040 gap. Probably with stock heat rating or one step cooler.
Reason I'm asking is that I (well Phil01) put some NGK BKR7EIX's on my car in preparation for boost. However, less than 300 miles later they seem to be toast. Thick carbon deposits all over them and rough idle.
My thinking is that now I'm running meth, I don't necessarily need to compensate the heat rating of the sparks too much. And the reason for so much carbon build-up could be that the sparks aren't running hot enough to burn it off?
Here's a pic:
[Image: l_sparkyandgeorge.jpg]
19-06-2018, 09:03 AM #1
Here's a pic:
27-06-2018, 11:44 PM
The answer in case anyone was wondering is : yes, yes they work.
Although not much use to those of us runnign N/A, boosted folks who are tuning their cars might be interested in them as not only are they copper, but they have 3 prongs which ensures that they will last a lot longer
27-06-2018, 11:44 PM #2
mattross1313
23-08-2018, 10:20 AM
Hey Folks, just bumping this thread as I need new plugs.
The past week the car has been starting the slightly miss fire whilst cruising, VERY slightly! And now has a pretty lumpy idle too. I am running the same plugs as Jim listed above, Iridium bkr7eix, they are waaaaay more sooted up than Jims photo.
What should I get? The same plugs again? Jim, you said they were ruined after very little millage, is that due to the setup of your car?
I see lots of the same plugs on eBay that I already have, but none listed forlexus? I assume any will do?
mattross1313
23-08-2018, 10:20 AM #3
23-08-2018, 10:32 AM
Yeah I think mine got knackered mostly because of the overly rich tune I was running at the time. What you can do though is spray them with some brake cleaner + wire brush and clean them up, and they should work like new.
However, I opted for slightly hotter plugs (6 heat rating) and also 3 prong copper ones. The advantage of this was that you get the best spark (copper), plus 3x the life of a traditional copper plug, plus if you misfire you melt the plug rather than sending bits of iridium into the cylinders
23-08-2018, 10:32 AM #4
Phil01
23-08-2018, 02:56 PM
copper plugs fire the best with a big fat spark.
the only advantage iridium or platinum plug over copper is their long service life, they do not fire any better, infact they do not fire as well as copper electrodes
Phil01
23-08-2018, 02:56 PM #5
23-08-2018, 03:29 PM
Is it not possible to get silver spark plugs? I'd have thought that would be a better choice as it's the most conductive metal known to man...
Must be some reason for not using it (other than expense, as spark plugs wouldn't need a lot of it)
But yes Iridium is just used to extend life as its incredibly hard wearing, so much so that the iridium tips on spark plugs have to be welded with lasers...
:Overkill:
23-08-2018, 03:29 PM #6
:Overkill:
23-08-2018, 04:02 PM
Yes you can get silver Spark plugs: http://www.nology.com/silver.html
23-08-2018, 04:02 PM #7
mattross1313
23-08-2018, 10:38 PM
Thanks Jim et all for the responses.
I will have a go at cleaning them up tonight just to see what happens, can't hurt to try really. I know that mine is running very rich also, so might be in the same boat as yourself. I'll report back Smile
mattross1313
23-08-2018, 10:38 PM #8
mattross1313
23-08-2018, 10:39 PM
Oh, one more thing, what should I gap these plugs to? never changed a Lexus before. it was 0.8mm on the MR2?
mattross1313
23-08-2018, 10:39 PM #9
23-08-2018, 10:49 PM
I was running BKR6ET-10 plugs on mine with the stock gapping. From what I remember the gap was optimal (for a F/I IS300 at least).
You probably won't find those plugs anywhere online, but ask a local car parts place that has dealings with NGK and they'll be able to get you some super quick.
23-08-2018, 10:49 PM #10
Views 590
10-05-2020, 10:47 AM
Last Post by Fry-Up
Views 861
26-02-2019, 01:01 AM
Last Post by Bandit
Views 1,987
29-11-2018, 10:32 AM
Last Post by IanS200
Views 1,330
19-06-2018, 07:25 AM
Last Post by jimxms
Replies 27
Views 2,361
19-03-2018, 04:29 AM
Last Post by jimxms
